MPC5777 CSE engine EC=14
1,805 次查看
Hanryyuan
when CSE_SR.EX, CSE_IR.CIF and CSE_CR.CIE set to 1, we Call one CSE_CMD=11, then disable CSE engine and re-enable CSE engine, finally, we will get the CSE_ECR.EC =14, could some one can help me what's the condition to trigger the EC ? does it relates to the CSE_CR.CIE= 1 ? thank you
4 回复数
1,761 次查看
lukaszadrapa
Hi @Hanryyuan
I read the description several times but it's still not clear to me. What's your goal and what's your exact code? Could you provide more detailed description?
Lukas
1,724 次查看
Hanryyuan
1,712 次查看
lukaszadrapa
Hi @Hanryyuan
I did quick test on my board and I can't see such behavior. I can disable and enable CSE without an error.
What's the value of C_CSE_CR_Register_Data? I can't see this on your screenshot. Maybe that's the difference against my code.
Anyway, I can't see a reason why to toggle MDIS in this way during initialization. That's not necessary.
Lukas
1,725 次查看
Hanryyuan
Hi Lukas,
My goal is to get clear the condition to trigger CSE_ECR.EC=14. when CSE_SR.EX =1, CSE_IR.CIF =1 , we call CSE cancel command 11, then disable CSE engine and reenable the CSE engine, the EC 14 was reported, is it the correct way to process CSE engine ? please get the CSE engine status before and after CSE engine init in attached pictures
