Reading temperature and voltage data
Arsenii
Hello.
Im started working with MPC5777C few days ago and trying to understand how to read raw voltage or temperature data. In reference manual i found a lot of data about  LVD and HVD self test, but cannot find anything about raw voltage (or temperature) data.
If i get it right i need to do the following:
1. Set PMC_ADC_CS to ADC voltage reference channel (what channel is it?).
2. Set ADC to conversion resolution (or its fixed 16 bit only?).
3. Enable specific ADC.
4. Trigger the conversion (how?).
5. Get result from SDADC_1-4.
6. Reset the buffers.
7. Disable ADC.
Please, fill the gaps if i forget something or (ideally) provide an example.
Thanks!
PetrS
below example shows MCU's temperature measurement with the help of TSENS;
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/Example-MPC5777C-TSENS-Temperature-calculation-G...
BR, Petr
