Hi Gyus,
On MPC5777c, we need to configure GPIO ID 117 with DSC set to its Maximum Drive Length; SIU_PCR117.[DSC]=11b. However, it cannot be set at all. The DSC is kept set to 00b.
Any explanation ?
Omar
Solved! Go to Solution.
this pin is Slow/Medium pad type and so PCR.SRC is controlling its slew rate, a DSC field is reserved, applicable for Fast type pads only.
BR, Petr
BR, Petr
Thank you, appreciated.
