Profiling on e200z7 (MPC5777C)?
constantinrazva
Hello guys,
Do you have any example profiling on MPC5777C using the e200z7 PMU?
From what I understand the flow should be something like this:
  • enter supervisor mode
  • freeze counters
  • clear counters
  • set up events (in my case Ref:1 - processor cycles)
  • enable counters
  • [code to be profiled]
  • get values of counters
  • get difference in cycles
I'd be great if you could direct me to an example of PMU.
Thanks in advance!
Razvan.
Tags (3)
lukaszadrapa
Hi Razvan,
we have this application note:
https://www.nxp.com/docs/en/application-note/AN4341.pdf
Lukas
