Power PC tutorial
Power PC tutorial
mhogun
Hi All,
I am using MPC5604s controller currently.
I am interested to learn  Power Architecture.
Kindly share me the documents like PPT,PDF of Power Architecture Tutorial.
Thanks in Advance
Mohanraj
petervlna
fraidling
Hello Peter,
the cookbook is for MPC55XX/56XX Microcontrollers.
I've read that the MPC57XX are similar to the MPC56XX, so i could use it for reference.
Yet i wanted to ask if there is an updated Version for MPC57XX "Hello World" Programs?
Florens
petervlna
I was in intention you are looking for MPC56xx.
For MPC5748G there is similar document:
http://www.nxp.com/assets/documents/data/en/application-notes/AN4830.pdf
If you are interested in examples you can check our database in community:
https://community.nxp.com/docs/DOC-329623
Peter
fraidling
You are right, the original post was about the MPC5604.
I am interested in software examples for the MPC5777C and found the software example list + the software initialization pdf.
The mentioned cookbook is linked in the documents too, but there are no MPC5777C examples (DSPI).
Do you have a similar document for the MPC5777C too?
Florens
petervlna
There is directly example for DSPI for MPC5646R which is previous compatible version of MPC5777C.
https://community.nxp.com/docs/DOC-334012
You can use it with no issues.
However there is no document directly dealing with DSPI on MPC5777C.
Peter
mhogun
Hi Peter,
Thank you for the support.
I have saw some of the tutorial in PPT in  nxp website and it is very much simple also easy to understand.
Can i get similar kind to learn  Power Architecture.?
Thanks in Advance
Mohanraj
