Power Component Layout
rayhall
Contributor V
Is there an application note or example of power component layout and recommended power plane design.
The MPC6xxxx requires a lot of capacitors and other components for power pins. My design is four layer with the two inner planes as power (5v) and ground. It looks like it is not possible to only use four layers and not make for a difficult layout to root.
Ray.
