OpenSDA S32R274
OpenSDA S32R274
longfeiwang
Does opensda support s32r274?If I do my own opensda,Does the USB bootloader in the chip come with itself or need to be obtained from other channels?
stanish
AFAIK OpenSDA does not support S32R274. Anyway to be 100% sure please check it with Pemicro support (OpenSDA release notes are not very specific about supported derivatives)
Regarding OpenSDA bootloader/application - Pemicro distributes it in a single package along with other OpenSDA firmwares:
http://www.pemicro.com/opensda/
The bootloader/application is distributed as .sda file and could be programmed e.g. by CycloneMAX programmer.
For more information about OpenSDA I'd suggest you to contact Pemicro Support.
Hope it helps.
Stan
stanish
Hope it helps.
Stan
