Need eSCI code for MPC5674F
ソリューションへジャンプ
3,806件の閲覧回数
rajiilangovan
Hi friend,
           Kindly give me the SCI and LIN mode configuration code for specific  MPC5674F.
3,505件の閲覧回数
davidtosenovjan
eSCI module is equal on MPC5674F and MPC55xx. You may simply port the code with using of following base project. Note that this code also configures eSCI for UART terminal:
https://community.freescale.com/docs/DOC-102744
4 返答(返信)
3,505件の閲覧回数
petervlna
You should look at Freescale web site. All the information you request are there.
Applicaiton note:
http://cache.freescale.com/files/32bit/doc/app_note/AN2865.pdf
Example codes:
MPC5500 and MPC5600 Simple Cookbook Code
3,505件の閲覧回数
rajiilangovan
Thank you friend
3,505件の閲覧回数
rajiilangovan
In that link the code id given for MPC55xx. I want MPC5674F code for eSCI.
3,506件の閲覧回数
davidtosenovjan
