Multicore MPC5748G FreeRTOS Example
Daniel_Wax
stanish‌ martinkovar
Im trying to put together a FreeRTOS example using all 3 MPC5748G cores.  Im having a tough time.  I am starting with the single core FreeRTOs example and duplicating it.  Trying to mimic the multicore interrupt example
All Id like to do is have one task scheduled to run in each core blinking an LED and be able to debug each core individually.
Ive added many things to the Project Properties Preprocessor defines like this:
-std=c99 -DSTART_FROM_FLASH -DCPU_MPC5748G -DTURN_ON_CPU0 -DTURN_ON_CPU1 -DTURN_ON_CPU2 -DDEBUG_SECONDARY_CORES USING_OS_FREERTOS
I get one of those "uncensored errors"
Has anyone an example of FreeRTOS running on each core?
lukaszadrapa
Hi Daniel,
Freertos is not a multi-core OS. Each core can host own freertos instance but it will require more effort to implement it due to shared resources. I'm not aware of such example.
Lukas
Daniel_Wax
I forgot to mention this a for a strategic automotive OEM in my region
SENT FROM PHONE
Daniel Wax | Field Applications Engineer Automotive
NXP Semiconductors
411 E Plumeria Dr
San Jose, CA 95134
office: 408-518-5533
mobile: 408-981-9220
[email protected]<mailto:[email protected]>
All types of technical support (Schematic review, layout review, software review, hardware board and software) provided
by NXP Field application team are subject to NXP's general Terms and Conditions unless superseded by a direct contract.
The information contained in this message is confidential and may be legally privileged. The message is intended solely for the addressee(s). If you are not the intended recipient, you are hereby notified that any use, dissemination, or reproduction is strictly prohibited and may be unlawful. If you are not the intended recipient, please contact the sender by return e-mail and destroy all copies of the original message.
Unless otherwise recorded in a written agreement, all sales transactions by NXP Semiconductors are subject to our general terms and conditions of commercial sale<http://www.nxp.com/about/our-terms-and-conditions-of-commercial-sale:TERMSCONDITIONSSALE?fsrch=1&sr=1&pageNum=1>.
lukaszadrapa
Hi ovidiu.alexandru‌,
maybe you could help. Do you know if anyone tried that? Or what is needed effort to do that?
Lukas
Daniel_Wax
Thanks Lukas. I understand it’s not a multi core OS. Was hoping to load three instances. One free RTOS for each core. Each instance also to load from an separate 256k flash partition
SENT FROM PHONE
NXP Semiconductors
411 E Plumeria Dr
San Jose, CA 95134
