MPC5775K STCU2 LBIST Configuration
6,075件の閲覧回数
danielreinoso
I'm trying to configure online LBIST, but I don't know values for configuration registers. I found an excel file for MPC5777M (find attached), but i need a file for my MCU (The LBIST partitions are different) Does anyone know if this file exists?
Thanks in advance!
7 返答(返信)
5,617件の閲覧回数
petervlna
There is an engineering bulletin describing the STCU2 configuration.
http://cache.nxp.com/files/microcontrollers/doc/eng_bulletin/EB823.pdf?fsrch=1&sr=2&pageNum=1
Peter
5,617件の閲覧回数
danielreinoso
Hello Peter,
Thank you for your answer.
The problem is that this bulletin is not enough for me. I want to know how to configure STCU_LB_PCSn,LB_MISRELSWn and MISREHSWn registers. I need something like the excel file attached in the question.
5,617件の閲覧回数
petervlna
There is no existing document for MPC5775K to cover a customization of BIST according to application team.
According to application team it is possible apply configuration described in  AN5131.
If you have any specific questions do not hesitate to ask me.
5,616件の閲覧回数
petervlna
Ok,
Here is the document aimed for MPC5775K. It can be used alongside with the DCF document attached to Reference manual of MPC5775K.
Peter
5,616件の閲覧回数
danielreinoso
I think this is the same engineering bulletin that you sent me in your previous response...
5,616件の閲覧回数
petervlna
I see,
sorry for that.Unfortunately I do not have the requested configuration table available.
I will discuss it with responsible application engineer and let you know if we can handle it.
Peter
5,616件の閲覧回数
danielreinoso
Ok,
Thank you very much Peter! :smileyhappy:
