MPC5775 OR S32R274 interrupt?
1,732件の閲覧回数
xiexiaopeng
Hi:
NOW I had a work on the S32R247, I used the PIT  interrupt, but I had a problem with it.
I could  configure the PIT,but I did not wirte the function of interrupt,I did not know where  found the interrupt vector table。
can you hlep me ?
thank you!
1,384件の閲覧回数
petervlna
Interrupt vectors sources are described in excel sheet attached to S32R274 reference manual.
Then attachment is inside reference manual (paperclip symbol)
Based on this table you can create interrupt vector table.
Or you can check our example on community:
https://community.nxp.com/docs/DOC-333702
Peter
