MPC5748G Spread Spectrum
3,404 次查看
nextsteve
Hi, I'm interested in trying out the spread spectrum feature of the MPC5748G PLL.
Wondering if there are reference register values available for STEPSIZE, STEPNO, etc. I could use to test quickly while I work through the equations.
Steve
标记 (2)
4 回复数
3,039 次查看
petervlna
I have created example SW for you.
My STEP is 250 and modulation frequency is 20kHz.
I have verified it with spectral analyzer. You can use it as a reference.
https://community.nxp.com/docs/DOC-334867
Peter
3,039 次查看
nextsteve
That is awesome Peter, Thanks!
3,039 次查看
petervlna
We do not have reference example for frequency modulation.
You have to calculate STEPSIZE and STEPNO.
From my past experience I recommend you after calculation to use spectral analyzer for manual fine tuning.
Peter
3,039 次查看
nextsteve
Hi Peter, does STEPSIZE need to be non-zero?
If so, then I don't see how the calc can possibly work because with a 40MHz crystal and modulation freq=10kHz --> STEPNO=2000. N would have to be >2000 for STEPSIZE to round to anything other than 0.
What am I missing?
Steve
