MPC5748G Flash Read
MPC5748G Flash Read
sohyunjang
Hi, I would like to read the Flash area of the MPC5748G.
When I read the Standard Software Driver for C55 Flash User 'Manual, it seems that there is no API reading Flash.
Can you provide example code for reading Flash?
 FlashInit
 FlashErase
 FlashEraseAlternate
 BlankCheck
 FlashProgram
 ProgramVerify
 CheckSum
 FlashCheckStatus
 FlashSuspend
 FlashResume
 GetLock
 SetLock
 OverPgmProtGetStatus
 FlashArrayIntegrityCheck
 FlashArrayIntegritySuspend
 FlashArrayIntegrityResume
 UserMarginReadCheck
 FlashAbort
 FlashAddressEncodeLogicCheck
 FlashECCLogicCheck
 FlashEDCAfterECCLogicCheck
 FlashExpressProgram
lukaszadrapa
there's no API in the flash drivers. You can simply read the flash using pointers. No special access is needed.
Lukas
lukaszadrapa
Lukas
