[MPC5748G] FIR filter design question
1,799 次查看
jzhang1
Does S32 Design studio have the ready-to-use library or function for the FIR filter? Like the command in Matlab "b = firpm(n,f,a)"https://www.mathworks.com/help/signal/ref/firpm.html#d120e59899
I want to design a bandpass or low-pass FIR filter to process the real-time data from the ADC module on the board.
I appreciate your help!
1,723 次查看
lukaszadrapa
Hi Junyi,
you can use FIR filter from AMMCLIB:
Automotive Math and Motor Control Library Set | NXP
The library is already integrated in the S32 Design Studio:
c:\NXP\S32DS_Power_v2.1\S32DS\software\AMMCLIB_1.1.15\MPC574xG_AMMCLIB_v1.1.15\
Search for  GDFLIB_FilterFIR in the documentation.
Lukas
1,724 次查看
lukaszadrapa
Hi Junyi,
Lukas
