MPC5748G Adding DCF record
rahulramakrishn
I am using S32DS to debug MPC5748G. I want to enable the HSM module in MPC5748G. I found that in order to activate the HSM module, I need to set the HSE bit via DCF record. But I didn't found a way to set the DCF record. How can I access the DCF record in order to enable the HSM module in MPC5748G?
Rahul Ramakrishnan
rahulramakrishn
The first 64 bits that is not written. The location can be identified by
the sequence FFFFFFFF.
In your case 00400380.
If u able to update the DCF record please inform me.
On Jul 3, 2018 8:14 PM, "[email protected]" <[email protected]>
yashkhatri0291
I tried writing on 380, 390 and even 400 but there was no success.
It cannot be written over those records. Do we need to take some read/write permission in HSM or is it given to us automatically. I want some insights over the HSM_Control register(A3F8_0000), wherein 2 keys are mentioned. Where do we use those keys?
I insist your and Peter's help in this subject.
yashkhatri0291
sorry the address is 0xA3F84000.
rahulramakrishn
I also stuck in this problem. I didn't found any way to overcome this. If
you found anything please let me know.
On Jul 4, 2018 4:08 AM, "[email protected]" <[email protected]>
rahulramakrishn
Thank for your support. I am new to this field and this is the first time I
am working with a board. Thank for your time.
Rahul Ramakrishnan
