MPC5744P Reset
MPC5744P Reset
2,235件の閲覧回数
Menna
I am trying to do a soft reset using these lines
MC_ME. MCTL.R = 0x00005AF0; */ writes the key
MC_ME. MCTL.R = 0x0000A50F; /* the inverted key is written */
But it takes around 26 seconds. Do you know why?
5 返答(返信)
2,224件の閲覧回数
Menna
Okay, am I using wrong registers?
2,215件の閲覧回数
petervlna
No the registers are correct.
I would check if there isnt anything external connected on reset pin, to hold it active. Since it is EVB there should be no issue.
But once you enter they keys the reset will happen immediately.
I wonder how you measure the reset line.
Peter
2,212件の閲覧回数
Menna
I power a led and initiate the reset after 500 msec. The led turns on again after 26 secs, which means the reset is taking 26 secs. I can attach you the model I am using if you want to double check.
Thanks in advance.
2,207件の閲覧回数
petervlna
Well, not exactly. This means, your routine which controls pin connected to LED change its state in SW after 26sec.
If you want to know how long reset takes, then measure by oscilloscope reset line on microcontroller.
Peter
2,226件の閲覧回数
petervlna
From your description of issue is not able to tell you why. I expect the issue in in your execution / measurement.
The reset is hardwired from ME module to RGM module. So once you enter mode change to enter reset, it will be executed within one clock.
Peter
