Lock/Unlock JTAG PowerPC e200z0
jeanaimemaxa
I would like to know how to lock/unlock (at software level) JTAG on PowerPC e200z0 (MPC56xx).
I did read this document:  AN4365: MPC56xx Flash Programming Through Nexus/JTAG – Application Note (nxp.com),
but i was not able to find an answer
What is the requirement to be able to lock/unlock and the JTAG ?
Jean Aimé MAXA
Abbass
Which document you used to find the document ?
Can you please share with us the link of the reference manuel used ?
Abbass
petervlna
I have used reference manual of MPC5604B:
https://www.nxp.com/webapp/Download?colCode=MPC5604BCRM
Peter
petervlna
To lock/unlock JTAG you simply follow the reference manual:
In case you want to unlock it via SW, then I suggest you to prepare routine to get Censorship into default state in your application in advance or you can always change it via JTAG access if password is known.
Peter
