MPC5744P PIL timeout error while receiving data from the rtiostream interface
1,257件の閲覧回数
sureshkumarvenk
Hello All,
1.    The timeout of 10 seconds for receiving data from the rtiostream interface has been exceeded error faced after 100% Programming in to the MCU - during PIL execution using MBDTool box [MATLAB 2016b] in devkit MPC5744P.
2. We faced below issue when executed NXP PIL environment example model "sim_pil_ref_model_pnt.mdl".
 "An error occurred while creating an instance of connectivity configuration class "pntpil.ConnectivityConfig". Check that this is a valid connectivity configuration class.
Caused by: block_diagram does not have a parameter named 'rbl_com_port'
Please share information if anyone faced same issue.
Sureshkumar V.
0 返答(返信)
