MPC5744P DCF
MPC5744P DCF
3,323 次查看
Du_0224
Respected NXP engineer: Hello, I am using MPC5744P, and I want to ask a question about DCF Records. I mistakenly write all the data in part of the address (0x00400200-0x00400300) of DCF Records as 00. This caused me to be unable to debug via JTAG (PEmicro). Is there any way to save it.
标记 (2)
3,313 次查看
davidtosenovjan
Unfortunately not. This is just the situation leading in permanent lock of the device.
UTEST area (where DCF records are being stored) is OTP area (one time programmable), once you program it you cannot erase it.
I am sorry for bad news.
3,314 次查看
davidtosenovjan
1,894 次查看
FKS
      Hello, I have a question. I found in the MPC5744P Reference Manual that there is a description about the factory erase mechanism. Does this mean that if I forget the password, I can use this mechanism to unlock it? If so, could you please provide some examples or notes to show me how to use the factory erase mechanism?
     Thank you very much. I am eagerly looking forward to your reply.FKS_0-1748425010912.pngFKS_0-1748425010912.png
标记 (1)
1,875 次查看
davidtosenovjan
This feature is not available for users, it can only be erased in NXP factory.
