MPC5744 Register Protection
Jamber_H
Some modules, such as MC_ME, can set the Register Protection, as shown in the fig.1, but some other modules, such as CMU_0, can't use this function, and it's soft lock bit not exist, as shown in the fig.2.
Another question, in the Protected Registers list, why different modules have same Base Address? as shown in the fig.3, CMU0 and CMU1 has a same Base Address 0xFBFB0200, is it correct?
petervlna
The note is correct.
The base address for all CMUs is 0xFBFB_0000.
f the Base Address is 0xFBFB0000, the SoftLock bit should be 0xFBFB0000+0x3800=0xFBFB3800, but this address is still not accseeable as is shown in fig below. So could you tell me how to calculate the CMUs' Mirror Address, SoftLock Address and HardLock Address?
You calculation is not correct.
You have to take base address of the register: which for 0xFBFB_0200 which is only valid for CMU modules, for other peripherals your base is base address of module.
So for soft locking of CMU0_ CSR register you will do write to 0xFBFB_2200.
And lock register you will see at address 0xFBFB_3880 for CMU0_CSR.
Peter
mayank22
Hi Peter ,
These are the Modules on which I am implementing Locking mechanism under Register Protection for MPC5746C.  -
    0xFFFB0140, /* CMU------------*/
    0xFFFB0040, /* FXOSC----------*/
    0xFFFB0180, /* MC_CGM --------*/
    0xFFFB8000, /* MC_ME ---------*/
    0xFFFA8000, /* MC_RGM --------*/
    0xFFF50000, /* MEMU_0 -------*/
    0xFFFB0080, /* PLLDIG --------*/
    0xFFFA0400, /* PMCDIG --------*/
    0xFFFC0000, /* SIUL2 ---------*/
    0xFFFB0100, /* SXOSC ---------*/
    0xFFF9C000 /* LPU_CTL -------*/
what I am facing that some module GCR and SLB bit are throwing bus error if tried to access. similarly for those module it is soft/hard lock is working , I can still face the same problem for few registers set. I am attaching two samples of screen shots where first one is working and you can see all register/mirror/SLB and GCR addresses enabled while in second case SLB &GCR throws error if try to use them.
what could be the reason for this different behavior ? if u want I can attach my manual calculations for register/mirror/SLB and GCR addresses.
petervlna
To make it easy, here are macros which can be used for configuring register protection.
/*PowerPC*/
#define REGPROTPPMIRROR 0x2000
#define REGPROTPPSLBR 0x3800
#define REGPROTPPGCR 0x3FFC
#define WRITE_WITH_LOCK_PP_8BIT(registeraddress, value)
#define WRITE_WITH_LOCK_PP_16BIT(registeraddress, value)
#define WRITE_WITH_LOCK_PP_32BIT(registeraddress, value)
#define GET_SOFTLOCK_PP(modulebaseaddress, registeraddress, value)
#define CLR_SOFTLOCK_PP_32BIT(modulebaseaddress, registeraddress)
#define CLR_SOFTLOCK_PP_16BIT(modulebaseaddress, registeraddress)
#define CLR_SOFTLOCK_PP_8BIT(modulebaseaddress, registeraddress)
#define SET_SOFTLOCK_PP_32BIT(modulebaseaddress, registeraddress)
#define SET_SOFTLOCK_PP_16BIT(modulebaseaddress, registeraddress)
#define SET_SOFTLOCK_PP_8BIT(modulebaseaddress, registeraddress)
#define SET_HARDLOCK_PP(modulebaseaddress)
#define USER_ACCESS_FORBIDDEN_PP(modulebaseaddress)
#define USER_ACCESS_ALLOWED_PP(modulebaseaddress)
 And usecase example:
 //16k - 32 bit,CAN1
CAN_6.MCR.B.MDIS = 0x0;
WRITE_WITH_LOCK_16K_32BIT((&CAN_6.MCR.R), 0xD890000F);
GET_SOFTLOCK_16K(&CAN_6, &CAN_6.MCR.R,&testik);
CLR_SOFTLOCK_16K_32BIT(&CAN_6, &CAN_6.MCR.R);
SET_SOFTLOCK_16K_32BIT(&CAN_6, &CAN_6.MCR.R);
//SET_HARDLOCK_16k(&CAN_6);
CAN_6.MCR.B.MDIS = 0x1;
USER_ACCESS_FORBIDDEN_16k(&CAN_6);
GET_GCR_16K(&CAN_6,&GCRvalue);
USER_ACCESS_ALLOWED_16k(&CAN_6);
Jamber_H
Hi Peter,
Thank you for your reply. Now I know what the NOTE means, which is a keypoint, and I have had a test, it works well.
Jamber
petervlna
Only registers listed in appendix A can be locked by register protection:
So not all registers in module support this feature. Usually its only safety relevant.
Well, that is copy paste typo in manual, please have a look at manual Addendum instead:
Here are the addresses:
#define CMU_0 (*(volatile struct CMU_tag *) 0xFBFB0200UL)
#define CMU_1 (*(volatile struct CMU_tag *) 0xFBFB0240UL)
#define CMU_2 (*(volatile struct CMU_tag *) 0xFBFB0280UL)
#define CMU_3 (*(volatile struct CMU_tag *) 0xFBFB02C0UL)
#define CMU_4 (*(volatile struct CMU_tag *) 0xFBFB0300UL)
Peter
Jamber_H
Hi Peter,
I think I find the answer, but I don't understand. Thanks for your screenshot I saw the NOTE and it said " All CMUs modules are in the same protected region with the base address aligned to the 16k - 0xFBFB_0000", what's the meaning of this?
If the Base Address is 0xFBFB0000, the SoftLock bit should be 0xFBFB0000+0x3800=0xFBFB3800, but this address is still not accseeable as is shown in fig below. So could you tell me how to calculate the CMUs' Mirror Address, SoftLock Address and HardLock Address?
It's so funny different with other modules.
Jamber
petervlna
Peter
Jamber_H
Hi Peter,
I think it's better understand if modified the value of "Offset" of CMU in Table2-77 to 0x200, 0x208, 0x20C, et.al. but now I get it anyway, thank you.
Best Regards
Jamber
Jamber_H
Hi Peter,
"Only registers listed in appendix A can be locked by register protection:", what confused me is the CMU0 module is right in the Appendix A, but I can't access its SoftLock bit, and I post the screenshot in my question.
Jamber
petervlna
Hmm strange,
I was not aware of this. Trying to think about how to calculate the address.
Let me test it here and I will come back to you ASAP.
best regards,
Peter
Jamber_H
Could someone help me please?
Jamber_H
I Test MC_ME, CMU, ADC, CTU, PWM, only CMU is failed to set softlock, other modules can set softlock succussfully. Why?
%3CLINGO-SUB%20id%3D%22lingo-sub-1261074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1261074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3ESome%20modules%2C%20such%20as%20MC_ME%2C%20can%20set%20the%20Register%20Protection%2C%20as%20shown%20in%20the%20fig.1%2C%20but%20some%20other%20modules%2C%20such%20as%20CMU_0%2C%20can't%20use%20this%20function%2C%20and%20it's%20soft%20lock%20bit%20not%20exist%2C%20as%20shown%20in%20the%20fig.2.%3C%2FP%3E%3CP%3EAnother%20question%2C%20in%20the%20Protected%20Registers%20list%2C%20why%20different%20modules%20have%20same%20Base%20Address%3F%20as%20shown%20in%20the%20fig.3%2C%20CMU0%20and%20CMU1%20has%20a%20same%20Base%20Address%200xFBFB0200%2C%20is%20it%20correct%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-13_151624.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-13_151624.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142103i750DC5EEDAB03D7C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-13_151624.png%22%20alt%3D%222021-04-13_151624.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-13_151502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-13_151502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142104i7268E737D5078B55%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-13_151502.png%22%20alt%3D%222021-04-13_151502.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-13_152957.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-13_152957.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142105i2BD0A71F38211B49%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-13_152957.png%22%20alt%3D%222021-04-13_152957.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2134847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Peter%20%2C%3C%2FP%3E%3CP%3EThese%20are%20the%20Modules%20on%20which%20I%20am%20implementing%20Locking%20mechanism%20under%20Register%20Protection%26nbsp%3Bfor%20MPC5746C.%26nbsp%3B%3CSPAN%3E%26nbsp%3B-%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%200xFFFB0140%2C%20%2F*%20CMU------------*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%200xFFFB0040%2C%20%2F*%20FXOSC----------*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%200xFFFB0180%2C%20%2F*%20MC_CGM%20--------*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%200xFFFB8000%2C%20%2F*%20MC_ME%20---------*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%200xFFFA8000%2C%20%2F*%20MC_RGM%20--------*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%200xFFF50000%2C%20%2F*%20MEMU_0%20-------*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%200xFFFB0080%2C%20%2F*%20PLLDIG%20--------*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%200xFFFA0400%2C%20%2F*%20PMCDIG%20--------*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%200xFFFC0000%2C%20%2F*%20SIUL2%20---------*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%200xFFFB0100%2C%20%2F*%20SXOSC%20---------*%2F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%200xFFF9C000%20%2F*%20LPU_CTL%20-------*%2F%3C%2FP%3E%3CP%3Ewhat%20I%20am%20facing%20that%20some%20module%20GCR%20and%20SLB%20bit%20are%20throwing%20bus%20error%20if%20tried%20to%20access.%20similarly%20for%20those%20module%20it%20is%20soft%2Fhard%20lock%20is%20working%20%2C%20I%20can%20still%20face%20the%20same%20problem%20for%20few%20registers%20set.%20I%20am%20attaching%20two%20samples%20of%20screen%20shots%20where%20first%20one%20is%20working%20and%20you%20can%20see%20all%20register%2Fmirror%2FSLB%20and%20GCR%20addresses%20enabled%20while%20in%20second%20case%20SLB%20%26amp%3BGCR%20throws%20error%20if%20try%20to%20use%20them.%26nbsp%3B%3C%2FP%3E%3CP%3Ewhat%20could%20be%20the%20reason%20for%20this%20different%20behavior%20%3F%20if%20u%20want%20I%20can%20attach%20my%20manual%20calculations%20for%26nbsp%3Bregister%2Fmirror%2FSLB%20and%20GCR%20addresses.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1263496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1263496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Peter%2C%3C%2FP%3E%3CP%3EI%20think%20it's%20better%20understand%20if%20modified%20the%20value%20of%20%22Offset%22%20of%20CMU%20in%20Table2-77%20to%200x200%2C%200x208%2C%200x20C%2C%20et.al.%20but%20now%20I%20get%20it%20anyway%2C%20thank%20you.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-16_184156.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-16_184156.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142512i791DB299DAAF1E20%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-16_184156.png%22%20alt%3D%222021-04-16_184156.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3EBest%20Regards%3C%2FP%3E%3CP%3EJamber%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1263490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1263490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Peter%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20reply.%20Now%20I%20know%20what%20the%20NOTE%20means%2C%20which%20is%20a%20keypoint%2C%20and%20I%20have%20had%20a%20test%2C%20it%20works%20well.%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3CP%3EJamber%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1263438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1263438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3ETo%20make%20it%20easy%2C%20here%20are%20macros%20which%20can%20be%20used%20for%20configuring%20register%20protection.%3C%2FP%3E%0A%3CPRE%3E%2F*PowerPC*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*-----------------------------------------------------------------------------------------------------------*%2F%3CBR%20%2F%3E%23define%20REGPROTPPMIRROR%200x2000%3CBR%20%2F%3E%23define%20REGPROTPPSLBR%200x3800%3CBR%20%2F%3E%23define%20REGPROTPPGCR%200x3FFC%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20WRITE_WITH_LOCK_PP_8BIT(registeraddress%2C%20value)%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%23define%20WRITE_WITH_LOCK_PP_16BIT(registeraddress%2C%20value)%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%23define%20WRITE_WITH_LOCK_PP_32BIT(registeraddress%2C%20value)%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20GET_SOFTLOCK_PP(modulebaseaddress%2C%20registeraddress%2C%20value)%3CBR%20%2F%3E%23define%20CLR_SOFTLOCK_PP_32BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%23define%20CLR_SOFTLOCK_PP_16BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%23define%20CLR_SOFTLOCK_PP_8BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20SET_SOFTLOCK_PP_32BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%23define%20SET_SOFTLOCK_PP_16BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%23define%20SET_SOFTLOCK_PP_8BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20SET_HARDLOCK_PP(modulebaseaddress)%3CBR%20%2F%3E%23define%20USER_ACCESS_FORBIDDEN_PP(modulebaseaddress)%3CBR%20%2F%3E%23define%20USER_ACCESS_ALLOWED_PP(modulebaseaddress)%3C%2FPRE%3E%0A%3CP%3E%26nbsp%3BAnd%20usecase%20example%3A%3C%2FP%3E%0A%3CDIV%20style%3D%22box-sizing%3A%20border-box%3B%20font-family%3A%20'Segoe%20UI'%2C%20system-ui%2C%20'Apple%20Color%20Emoji'%2C%20'Segoe%20UI%20Emoji'%2C%20sans-serif%3B%20font-size%3A%2014px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%22%3E%0A%3CPRE%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%236888c9%3B%22%3E%2F%2F16k%20-%2032%20bit%2CCAN1%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x0%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20WRITE_WITH_LOCK_16K_32BIT((%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E)%2C%200xD890000F)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_SOFTLOCK_16K(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%2C%26amp%3Btestik)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x0%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CLR_SOFTLOCK_16K_32BIT(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_SOFTLOCK_16K(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%2C%26amp%3Btestik)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x0%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20SET_SOFTLOCK_16K_32BIT(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_SOFTLOCK_16K(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%2C%26amp%3Btestik)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%236888c9%3B%22%3E%2F%2FSET_HARDLOCK_16k(%26amp%3BCAN_6)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CLR_SOFTLOCK_16K_32BIT(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_SOFTLOCK_16K(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%2C%26amp%3Btestik)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x1%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20USER_ACCESS_FORBIDDEN_16k(%26amp%3BCAN_6)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_GCR_16K(%26amp%3BCAN_6%2C%26amp%3BGCRvalue)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x0%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20USER_ACCESS_ALLOWED_16k(%26amp%3BCAN_6)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_GCR_16K(%26amp%3BCAN_6%2C%26amp%3BGCRvalue)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x0%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20SET_HARDLOCK_16k(%26amp%3BCAN_6)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_GCR_16K(%26amp%3BCAN_6%2C%26amp%3BGCRvalue)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1263427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1263427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThe%20note%20is%20correct.%3C%2FP%3E%0A%3CP%3EThe%20base%20address%20for%20all%20CMUs%20is%20%3CFONT%20color%3D%22%23FF0000%22%3E%3CSPAN%20class%3D%22fontstyle0%22%3E0xFBFB_0000%3C%2FSPAN%3E%3C%2FFONT%3E.%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3Ef%20the%20Base%20Address%20is%200xFBFB0000%2C%20the%20SoftLock%20bit%20should%20be%200xFBFB0000%2B0x3800%3D0xFBFB3800%2C%20but%20this%20address%20is%20still%20not%20accseeable%20as%20is%20shown%20in%20fig%20below.%20So%20could%20you%20tell%20me%20how%20to%20calculate%20the%20CMUs'%20Mirror%20Address%2C%20SoftLock%20Address%20and%20HardLock%20Address%3F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3EYou%20calculation%20is%20not%20correct.%3C%2FP%3E%0A%3CP%3EYou%20have%20to%20take%20base%20address%20of%20the%20register%3A%20which%20for%200xFBFB_0200%20which%20is%20only%20valid%20for%20CMU%20modules%2C%20for%20other%20peripherals%20your%20base%20is%20base%20address%20of%20module.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1618563997092.png%22%20style%3D%22width%3A%20532px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1618563997092.png%22%20style%3D%22width%3A%20532px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142492i488A18CFB3D0B5CE%2Fimage-dimensions%2F532x28%3Fv%3Dv2%22%20width%3D%22532%22%20height%3D%2228%22%20role%3D%22button%22%20title%3D%22petervlna_1-1618563997092.png%22%20alt%3D%22petervlna_1-1618563997092.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1618563954927.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1618563954927.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142491i8D71FFF8F2B0CCA9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_0-1618563954927.png%22%20alt%3D%22petervlna_0-1618563954927.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESo%20for%20soft%20locking%20of%20CMU0_%20CSR%20register%20you%20will%20do%20write%20to%200xFBFB_2200.%3C%2FP%3E%0A%3CP%3EAnd%20lock%20register%20you%20will%20see%20at%20address%200xFBFB_3880%20for%20CMU0_CSR.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1262757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1262757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHmm%20strange%2C%3C%2FP%3E%0A%3CP%3EI%20was%20not%20aware%20of%20this.%20Trying%20to%20think%20about%20how%20to%20calculate%20the%20address.%3C%2FP%3E%0A%3CP%3ELet%20me%20test%20it%20here%20and%20I%20will%20come%20back%20to%20you%20ASAP.%3C%2FP%3E%0A%3CP%3Ebest%20regards%2C%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1262681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1262681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Peter%2C%3C%2FP%3E%3CP%3EI%20think%20I%20find%20the%20answer%2C%20but%20I%20don't%20understand.%20Thanks%20for%20your%20screenshot%20I%20saw%20the%20NOTE%20and%20it%20said%20%22%20%3CFONT%20color%3D%22%23FF0000%22%3E%3CSPAN%20class%3D%22fontstyle0%22%3EAll%20CMUs%20modules%20are%20in%20the%20same%20protected%20region%20with%20the%20base%20address%20aligned%20to%20the%2016k%20-%200xFBFB_0000%3C%2FSPAN%3E%3C%2FFONT%3E%22%2C%20what's%20the%20meaning%20of%20this%3F%3C%2FP%3E%3CP%3EIf%20the%20Base%20Address%20is%200xFBFB0000%2C%20the%20SoftLock%20bit%20should%20be%200xFBFB0000%2B0x3800%3D0xFBFB3800%2C%20but%20this%20address%20is%20still%20not%20accseeable%20as%20is%20shown%20in%20fig%20below.%20So%20could%20you%20tell%20me%20how%20to%20calculate%20the%20CMUs'%20Mirror%20Address%2C%20SoftLock%20Address%20and%20HardLock%20Address%3F%3C%2FP%3E%3CP%3EIt's%20so%20funny%20different%20with%20other%20modules.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-15_164430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-15_164430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142350iCB5F08904AF719C7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-15_164430.png%22%20alt%3D%222021-04-15_164430.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-15_164141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-15_164141.png%22%20style%3D%22width%3A%20391px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142351iC911E02E1280A248%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-15_164141.png%22%20alt%3D%222021-04-15_164141.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3CP%3EJamber%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1262639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1262639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Peter%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3EThank%20you%20for%20your%20reply.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CFONT%20color%3D%22%230000FF%22%3E%3CEM%3EOnly%20registers%20listed%20in%20appendix%20A%20can%20be%20locked%20by%20register%20protection%3A%3C%2FEM%3E%3C%2FFONT%3E%3CSPAN%3E%22%2C%20what%20confused%20me%20is%20the%20CMU0%20module%20is%20right%20in%20the%20Appendix%20A%2C%20but%20I%20can't%20access%20its%20SoftLock%20bit%2C%20and%20I%20post%20the%20screenshot%20in%20my%20question.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBest%20Regards%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EJamber%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1262586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1262586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EOnly%20registers%20listed%20in%20appendix%20A%20can%20be%20locked%20by%20register%20protection%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1618472142468.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1618472142468.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142330i186C0B3B86FA91C2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_0-1618472142468.png%22%20alt%3D%22petervlna_0-1618472142468.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESo%20not%20all%20registers%20in%20module%20support%20this%20feature.%20Usually%20its%20only%20safety%20relevant.%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3EAnother%20question%2C%20in%20the%20Protected%20Registers%20list%2C%20why%20different%20modules%20have%20same%20Base%20Address%3F%20as%20shown%20in%20the%20fig.3%2C%20CMU0%20and%20CMU1%20has%20a%20same%20Base%20Address%200xFBFB0200%2C%20is%20it%20correct%3F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3EWell%2C%20that%20is%20copy%20paste%20typo%20in%20manual%2C%20please%20have%20a%20look%20at%20manual%20Addendum%20instead%3A%3C%2FP%3E%0A%3CP%3EHere%20are%20the%20addresses%3A%3C%2FP%3E%0A%3CP%3E%23define%20CMU_0%20(*(volatile%20struct%20CMU_tag%20*)%200xFBFB0200UL)%3CBR%20%2F%3E%23define%20CMU_1%20(*(volatile%20struct%20CMU_tag%20*)%200xFBFB0240UL)%3CBR%20%2F%3E%23define%20CMU_2%20(*(volatile%20struct%20CMU_tag%20*)%200xFBFB0280UL)%3CBR%20%2F%3E%23define%20CMU_3%20(*(volatile%20struct%20CMU_tag%20*)%200xFBFB02C0UL)%3CBR%20%2F%3E%23define%20CMU_4%20(*(volatile%20struct%20CMU_tag%20*)%200xFBFB0300UL)%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1618472584102.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1618472584102.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142334i8F23C73A19733F3A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_1-1618472584102.png%22%20alt%3D%22petervlna_1-1618472584102.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1262009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1262009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECould%20someone%20help%20me%20please%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1261623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1261623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20Test%20MC_ME%2C%20CMU%2C%20ADC%2C%20CTU%2C%20PWM%2C%20only%20CMU%20is%20failed%20to%20set%20softlock%2C%20other%20modules%20can%20set%20softlock%20succussfully.%20Why%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
