MPC5744 Register Protection
14,314件の閲覧回数
Jamber_H
Some modules, such as MC_ME, can set the Register Protection, as shown in the fig.1, but some other modules, such as CMU_0, can't use this function, and it's soft lock bit not exist, as shown in the fig.2.
Another question, in the Protected Registers list, why different modules have same Base Address? as shown in the fig.3, CMU0 and CMU1 has a same Base Address 0xFBFB0200, is it correct?
14,242件の閲覧回数
petervlna
The note is correct.
The base address for all CMUs is 0xFBFB_0000.
f the Base Address is 0xFBFB0000, the SoftLock bit should be 0xFBFB0000+0x3800=0xFBFB3800, but this address is still not accseeable as is shown in fig below. So could you tell me how to calculate the CMUs' Mirror Address, SoftLock Address and HardLock Address?
You calculation is not correct.
You have to take base address of the register: which for 0xFBFB_0200 which is only valid for CMU modules, for other peripherals your base is base address of module.
So for soft locking of CMU0_ CSR register you will do write to 0xFBFB_2200.
And lock register you will see at address 0xFBFB_3880 for CMU0_CSR.
Peter
11 返答(返信)
8,138件の閲覧回数
mayank22
Hi Peter ,
These are the Modules on which I am implementing Locking mechanism under Register Protection for MPC5746C.  -
    0xFFFB0140, /* CMU------------*/
    0xFFFB0040, /* FXOSC----------*/
    0xFFFB0180, /* MC_CGM --------*/
    0xFFFB8000, /* MC_ME ---------*/
    0xFFFA8000, /* MC_RGM --------*/
    0xFFF50000, /* MEMU_0 -------*/
    0xFFFB0080, /* PLLDIG --------*/
    0xFFFA0400, /* PMCDIG --------*/
    0xFFFC0000, /* SIUL2 ---------*/
    0xFFFB0100, /* SXOSC ---------*/
    0xFFF9C000 /* LPU_CTL -------*/
what I am facing that some module GCR and SLB bit are throwing bus error if tried to access. similarly for those module it is soft/hard lock is working , I can still face the same problem for few registers set. I am attaching two samples of screen shots where first one is working and you can see all register/mirror/SLB and GCR addresses enabled while in second case SLB &GCR throws error if try to use them.
what could be the reason for this different behavior ? if u want I can attach my manual calculations for register/mirror/SLB and GCR addresses.
14,234件の閲覧回数
petervlna
To make it easy, here are macros which can be used for configuring register protection.
/*PowerPC*/
#define REGPROTPPMIRROR 0x2000
#define REGPROTPPSLBR 0x3800
#define REGPROTPPGCR 0x3FFC
#define WRITE_WITH_LOCK_PP_8BIT(registeraddress, value)
#define WRITE_WITH_LOCK_PP_16BIT(registeraddress, value)
#define WRITE_WITH_LOCK_PP_32BIT(registeraddress, value)
#define GET_SOFTLOCK_PP(modulebaseaddress, registeraddress, value)
#define CLR_SOFTLOCK_PP_32BIT(modulebaseaddress, registeraddress)
#define CLR_SOFTLOCK_PP_16BIT(modulebaseaddress, registeraddress)
#define CLR_SOFTLOCK_PP_8BIT(modulebaseaddress, registeraddress)
#define SET_SOFTLOCK_PP_32BIT(modulebaseaddress, registeraddress)
#define SET_SOFTLOCK_PP_16BIT(modulebaseaddress, registeraddress)
#define SET_SOFTLOCK_PP_8BIT(modulebaseaddress, registeraddress)
#define SET_HARDLOCK_PP(modulebaseaddress)
#define USER_ACCESS_FORBIDDEN_PP(modulebaseaddress)
#define USER_ACCESS_ALLOWED_PP(modulebaseaddress)
 And usecase example:
 //16k - 32 bit,CAN1
CAN_6.MCR.B.MDIS = 0x0;
WRITE_WITH_LOCK_16K_32BIT((&CAN_6.MCR.R), 0xD890000F);
GET_SOFTLOCK_16K(&CAN_6, &CAN_6.MCR.R,&testik);
CLR_SOFTLOCK_16K_32BIT(&CAN_6, &CAN_6.MCR.R);
SET_SOFTLOCK_16K_32BIT(&CAN_6, &CAN_6.MCR.R);
//SET_HARDLOCK_16k(&CAN_6);
CAN_6.MCR.B.MDIS = 0x1;
USER_ACCESS_FORBIDDEN_16k(&CAN_6);
GET_GCR_16K(&CAN_6,&GCRvalue);
USER_ACCESS_ALLOWED_16k(&CAN_6);
14,230件の閲覧回数
Jamber_H
Hi Peter,
Thank you for your reply. Now I know what the NOTE means, which is a keypoint, and I have had a test, it works well.
Jamber
14,276件の閲覧回数
petervlna
Only registers listed in appendix A can be locked by register protection:
So not all registers in module support this feature. Usually its only safety relevant.
Well, that is copy paste typo in manual, please have a look at manual Addendum instead:
Here are the addresses:
#define CMU_0 (*(volatile struct CMU_tag *) 0xFBFB0200UL)
#define CMU_1 (*(volatile struct CMU_tag *) 0xFBFB0240UL)
#define CMU_2 (*(volatile struct CMU_tag *) 0xFBFB0280UL)
#define CMU_3 (*(volatile struct CMU_tag *) 0xFBFB02C0UL)
#define CMU_4 (*(volatile struct CMU_tag *) 0xFBFB0300UL)
Peter
14,270件の閲覧回数
Jamber_H
Hi Peter,
I think I find the answer, but I don't understand. Thanks for your screenshot I saw the NOTE and it said " All CMUs modules are in the same protected region with the base address aligned to the 16k - 0xFBFB_0000", what's the meaning of this?
If the Base Address is 0xFBFB0000, the SoftLock bit should be 0xFBFB0000+0x3800=0xFBFB3800, but this address is still not accseeable as is shown in fig below. So could you tell me how to calculate the CMUs' Mirror Address, SoftLock Address and HardLock Address?
It's so funny different with other modules.
Jamber
14,243件の閲覧回数
petervlna
Peter
14,229件の閲覧回数
Jamber_H
Hi Peter,
I think it's better understand if modified the value of "Offset" of CMU in Table2-77 to 0x200, 0x208, 0x20C, et.al. but now I get it anyway, thank you.
Best Regards
Jamber
14,273件の閲覧回数
Jamber_H
Hi Peter,
"Only registers listed in appendix A can be locked by register protection:", what confused me is the CMU0 module is right in the Appendix A, but I can't access its SoftLock bit, and I post the screenshot in my question.
Jamber
14,265件の閲覧回数
petervlna
Hmm strange,
I was not aware of this. Trying to think about how to calculate the address.
Let me test it here and I will come back to you ASAP.
best regards,
Peter
14,292件の閲覧回数
Jamber_H
Could someone help me please?
14,299件の閲覧回数
Jamber_H
I Test MC_ME, CMU, ADC, CTU, PWM, only CMU is failed to set softlock, other modules can set softlock succussfully. Why?
%3CLINGO-SUB%20id%3D%22lingo-sub-1261074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC5744%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E4%BF%9D%E8%AD%B7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1261074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3EMC_ME%20%E3%81%AA%E3%81%A9%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E5%9B%B3%201%20%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E4%BF%9D%E8%AD%B7%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81CMU_0%20%E3%81%AA%E3%81%A9%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E5%9B%B3%202%20%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%82%BD%E3%83%95%E3%83%88%20%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E4%BF%9D%E8%AD%B7%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A7%E3%80%81%E3%81%AA%E3%81%9C%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E5%90%8C%E3%81%98%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%8C%81%E3%81%A4%E3%81%AE%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%9B%B33%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81CMU0%20%E3%81%A8%20CMU1%20%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E5%90%8C%E3%81%98%200xFBFB0200%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-13_151624.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-13_151624.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142103i750DC5EEDAB03D7C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-13_151624.png%22%20alt%3D%222021-04-13_151624.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-13_151502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-13_151502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142104i7268E737D5078B55%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-13_151502.png%22%20alt%3D%222021-04-13_151502.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-13_152957.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-13_152957.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142105i2BD0A71F38211B49%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-13_152957.png%22%20alt%3D%222021-04-13_152957.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2134847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E3%80%81MPC5746C%20%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E4%BF%9D%E8%AD%B7%E3%81%AE%E4%B8%8B%E3%81%A7%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%20%3CSPAN%3E-%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E0xFFFB0140%2C%20%2F*%20CMU------------*%2F%3C%2FP%3E%3CP%3E0xFFFB0040%2C%20%2F*%20FXOSC----------*%2F%3C%2FP%3E%3CP%3E0xFFFB0180%2C%20%2F*%20MC_CGM%20--------*%2F%3C%2FP%3E%3CP%3E0xFFFB8000%2C%20%2F*%20MC_ME%20---------*%2F%3C%2FP%3E%3CP%3E0xFFFA8000%2C%20%2F*%20MC_RGM%20--------*%2F%3C%2FP%3E%3CP%3E0xFFF50000%2C%20%2F*%20MEMU_0%20-------*%2F%3C%2FP%3E%3CP%3E0xFFFB0080%2C%20%2F*%20PLLDIG%20--------*%2F%3C%2FP%3E%3CP%3E0xFFFA0400%2C%20%2F*%20PMCDIG%20--------*%2F%3C%2FP%3E%3CP%3E0xFFFC0000%2C%20%2F*%20SIUL2%20---------*%2F%3C%2FP%3E%3CP%3E0xFFFB0100%2C%20%2F*%20SXOSC%20---------*%2F%3C%2FP%3E%3CP%3E0xFFF9C000%20%2F*%20LPU_CTL%20-------*%2F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%20GCR%20%E3%81%A8%20SLB%20%E3%83%93%E3%83%83%E3%83%88%E3%81%8C%E3%83%90%E3%82%B9%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E3%82%B9%E3%83%AD%E3%83%BC%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%2F%E3%83%8F%E3%83%BC%E3%83%89%20%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8CCAN%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%202%20%E3%81%A4%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%2F%E3%83%9F%E3%83%A9%E3%83%BC%2FSLB%20%E3%81%8A%E3%82%88%E3%81%B3%20GCR%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%812%20%E7%95%AA%E7%9B%AE%E3%81%AECASE%E3%81%A7%E3%81%AF%20SLB%20%E3%81%A8%20GCR%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E5%8B%95%E4%BD%9C%E3%81%AE%E7%90%86%E7%94%B1%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%94%E5%B8%8C%E6%9C%9B%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%2F%E3%83%9F%E3%83%A9%E3%83%BC%2FSLB%20%E3%81%8A%E3%82%88%E3%81%B3%20GCR%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E6%89%8B%E5%8B%95%E8%A8%88%E7%AE%97%E7%B5%90%E6%9E%9C%E3%82%92%E6%B7%BB%E4%BB%98CAN%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1263496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1263496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%E8%A1%A82-77%E3%81%AECMU%E3%81%AE%E3%80%8C%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%80%8D%E3%81%AE%E5%80%A4%E3%82%920x200%E3%80%810x208%E3%80%810x20C%E3%81%AA%E3%81%A9%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%88%E3%82%8A%E7%90%86%E8%A7%A3%E3%81%97%E3%82%84%E3%81%99%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A7%E3%82%82%E4%BB%8A%E3%81%AF%E3%81%A8%E3%81%AB%E3%81%8B%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-16_184156.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-16_184156.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142512i791DB299DAAF1E20%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-16_184156.png%22%20alt%3D%222021-04-16_184156.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%90%E3%83%BC%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1263490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1263490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%8A%E3%81%A7%E3%81%AF%E3%80%81%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A7%E3%81%82%E3%82%8B%20NOTE%20%E3%81%AE%E6%84%8F%E5%91%B3%E3%81%8C%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%82%82%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%90%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1263438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1263438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E7%B0%A1%E5%8D%98%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E4%BF%9D%E8%AD%B7%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%9E%E3%82%AF%E3%83%AD%E3%82%92%E6%AC%A1%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3E%2F*PowerPC*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*-----------------------------------------------------------------------------------------------------------*%2F%3CBR%20%2F%3E%23define%20REGPROTPPMIRROR%200x2000%3CBR%20%2F%3E%23define%20REGPROTPPSLBR%200x3800%3CBR%20%2F%3E%23define%20REGPROTPPGCR%200x3FFC%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20WRITE_WITH_LOCK_PP_8BIT(registeraddress%2C%20value)%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%23define%20WRITE_WITH_LOCK_PP_16BIT(registeraddress%2C%20value)%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%23define%20WRITE_WITH_LOCK_PP_32BIT(registeraddress%2C%20value)%26nbsp%3B%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20GET_SOFTLOCK_PP(modulebaseaddress%2C%20registeraddress%2C%20value)%3CBR%20%2F%3E%23define%20CLR_SOFTLOCK_PP_32BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%23define%20CLR_SOFTLOCK_PP_16BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%23define%20CLR_SOFTLOCK_PP_8BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20SET_SOFTLOCK_PP_32BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%23define%20SET_SOFTLOCK_PP_16BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%23define%20SET_SOFTLOCK_PP_8BIT(modulebaseaddress%2C%20registeraddress)%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20SET_HARDLOCK_PP(modulebaseaddress)%3CBR%20%2F%3E%23define%20USER_ACCESS_FORBIDDEN_PP(modulebaseaddress)%3CBR%20%2F%3E%23define%20USER_ACCESS_ALLOWED_PP(modulebaseaddress)%3C%2FPRE%3E%0A%3CP%3E%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AE%E4%BE%8B%3A%3C%2FP%3E%0A%3CDIV%20style%3D%22box-sizing%3A%20border-box%3B%20font-family%3A%20'Segoe%20UI'%2C%20system-ui%2C%20'Apple%20Color%20Emoji'%2C%20'Segoe%20UI%20Emoji'%2C%20sans-serif%3B%20font-size%3A%2014px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%22%3E%0A%3CPRE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%236888c9%3B%22%3E%2F%2F16k%20-%2032%20bit%2CCAN1%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x0%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20WRITE_WITH_LOCK_16K_32BIT((%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E)%2C%200xD890000F)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_SOFTLOCK_16K(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%2C%26amp%3Btestik)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x0%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CLR_SOFTLOCK_16K_32BIT(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_SOFTLOCK_16K(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%2C%26amp%3Btestik)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x0%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20SET_SOFTLOCK_16K_32BIT(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_SOFTLOCK_16K(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%2C%26amp%3Btestik)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%236888c9%3B%22%3E%2F%2FSET_HARDLOCK_16k(%26amp%3BCAN_6)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CLR_SOFTLOCK_16K_32BIT(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_SOFTLOCK_16K(%26amp%3BCAN_6%2C%20%26amp%3BCAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3ER%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%2C%26amp%3Btestik)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x1%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20USER_ACCESS_FORBIDDEN_16k(%26amp%3BCAN_6)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_GCR_16K(%26amp%3BCAN_6%2C%26amp%3BGCRvalue)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x0%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20USER_ACCESS_ALLOWED_16k(%26amp%3BCAN_6)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_GCR_16K(%26amp%3BCAN_6%2C%26amp%3BGCRvalue)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20CAN_6.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMCR%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EB%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E.%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3EMDIS%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20%3D%200x0%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20SET_HARDLOCK_16k(%26amp%3BCAN_6)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Consolas%3B%22%3E%20GET_GCR_16K(%26amp%3BCAN_6%2C%26amp%3BGCRvalue)%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1263427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1263427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%A1%E3%83%A2%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20CMU%20%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%3CFONT%20color%3D%22%23FF0000%22%3E%3CSPAN%20class%3D%22fontstyle0%22%3E0xFBFB_0000%3C%2FSPAN%3E%3C%2FFONT%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%200xFBFB0000%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81SoftLock%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%200xFBFB0000%2B0x3800%3D0xFBFB3800%20%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%B8%8B%E3%81%AE%E5%9B%B3%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E3%81%BE%E3%81%A0%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82CMU%20%E3%81%AE%E3%83%9F%E3%83%A9%E3%83%BC%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%A8%88%E7%AE%97%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%820xFBFB_0200%20%E3%81%AF%20CMU%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%81%AE%E3%81%BF%E6%9C%89%E5%8A%B9%E3%81%A7%E3%80%81%E4%BB%96%E3%81%AE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AF%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1618563997092.png%22%20style%3D%22width%3A%20532px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1618563997092.png%22%20style%3D%22width%3A%20532px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142492i488A18CFB3D0B5CE%2Fimage-dimensions%2F532x28%3Fv%3Dv2%22%20width%3D%22532%22%20height%3D%2228%22%20role%3D%22button%22%20title%3D%22petervlna_1-1618563997092.png%22%20alt%3D%22petervlna_1-1618563997092.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1618563954927.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1618563954927.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142491i8D71FFF8F2B0CCA9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_0-1618563954927.png%22%20alt%3D%22petervlna_0-1618563954927.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESO%E3%80%81CMU0_%20CSR%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%20%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%810xFBFB_2200%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%80%81CMU0_CSR%20%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200xFBFB_3880%20%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1262757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1262757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%86%E3%83%BC%E3%82%93%E3%80%81%E5%A5%87%E5%A6%99%E3%81%A7%E3%81%99%E3%81%AD%E3%80%81%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BD%8F%E6%89%80%E3%81%AE%E8%A8%88%E7%AE%97%E6%96%B9%E6%B3%95%E3%82%92%E8%80%83%E3%81%88%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1262681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1262681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%E7%AD%94%E3%81%88%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%86%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%B3%A8%E8%A8%98%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%80%8C%3CFONT%20color%3D%22%23FF0000%22%3E%3CSPAN%20class%3D%22fontstyle0%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20CMU%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%2016k%20-%200xFBFB_0000%20%E3%81%AB%E6%8F%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%9F%E5%90%8C%E3%81%98%E4%BF%9D%E8%AD%B7%E9%A0%98%E5%9F%9F%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FFONT%3E%E3%80%8D%E3%81%A8%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%200xFBFB0000%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81SoftLock%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%200xFBFB0000%2B0x3800%3D0xFBFB3800%20%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%B8%8B%E3%81%AE%E5%9B%B3%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E3%81%BE%E3%81%A0%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82CMU%20%E3%81%AE%E3%83%9F%E3%83%A9%E3%83%BC%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A8%E9%81%95%E3%81%A3%E3%81%A6SO%E9%9D%A2%E7%99%BD%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-15_164430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-15_164430.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142350iCB5F08904AF719C7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-15_164430.png%22%20alt%3D%222021-04-15_164430.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222021-04-15_164141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222021-04-15_164141.png%22%20style%3D%22width%3A%20391px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142351iC911E02E1280A248%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222021-04-15_164141.png%22%20alt%3D%222021-04-15_164141.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%90%E3%83%BC%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1262639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1262639%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%80%8C%3C%2FSPAN%3E%3CFONT%20color%3D%22%230000FF%22%3E%3CEM%3E%E4%BB%98%E9%8C%B2%20A%20%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E3%81%BF%E3%81%8C%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E4%BF%9D%E8%AD%B7%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%20%3CSPAN%3E%E3%80%8D%E3%80%81%E7%A7%81%E3%81%8C%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81CMU0%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E4%BB%98%E9%8C%B2%20A%20%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%81%9D%E3%81%AE%20SoftLock%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E8%B3%AA%E5%95%8F%E3%81%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%90%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1262586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1262586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E4%BF%9D%E8%AD%B7%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E4%BB%98%E9%8C%B2%20A%20%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1618472142468.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1618472142468.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142330i186C0B3B86FA91C2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_0-1618472142468.png%22%20alt%3D%22petervlna_0-1618472142468.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESO%E3%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%80%9A%E5%B8%B8%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E3%82%BB%E3%83%BC%E3%83%95%E3%83%86%E3%82%A3%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E4%BF%9D%E8%AD%B7%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A7%E3%80%81%E3%81%AA%E3%81%9C%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E5%90%8C%E3%81%98%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%8C%81%E3%81%A4%E3%81%AE%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%9B%B33%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81CMU0%20%E3%81%A8%20CMU1%20%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E5%90%8C%E3%81%98%200xFBFB0200%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%99%E3%81%AD%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%EF%BC%86%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%88%E3%81%AE%E8%AA%A4%E5%AD%97%E3%81%A7%E3%81%99%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E8%A3%9C%E8%B6%B3%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%8F%E6%89%80%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FP%3E%0A%3CP%3E%23define%20CMU_0%20(*(%E6%8F%AE%E7%99%BA%E6%80%A7%E6%A7%8B%E9%80%A0%E4%BD%93%20CMU_tag%20*)%200xFBFB0200UL)%3CBR%20%2F%3E%20%23define%20CMU_1%20(*(%E6%8F%AE%E7%99%BA%E6%80%A7%E6%A7%8B%E9%80%A0%E4%BD%93%20CMU_tag%20*)%200xFBFB0240UL)%3CBR%20%2F%3E%20%23define%20CMU_2%20(*(%E6%8F%AE%E7%99%BA%E6%80%A7%E6%A7%8B%E9%80%A0%E4%BD%93%20CMU_tag%20*)%200xFBFB0280UL)%3CBR%20%2F%3E%20%23CMU_3%20%E3%82%92%E5%AE%9A%E7%BE%A9%20(*(%E6%8F%AE%E7%99%BA%E6%80%A7%E6%A7%8B%E9%80%A0%E4%BD%93%20CMU_tag%20*)%200xFBFB02C0UL)%3CBR%20%2F%3E%20%23define%20CMU_4%20(*(%E6%8F%AE%E7%99%BA%E6%80%A7%E6%A7%8B%E9%80%A0%E4%BD%93%20CMU_tag%20*)%200xFBFB0300UL)%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1618472584102.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1618472584102.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F142334i8F23C73A19733F3A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_1-1618472584102.png%22%20alt%3D%22petervlna_1-1618472584102.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1262009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1262009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AA%B0%E3%81%8B%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1261623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5744%20Register%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1261623%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMC_ME%E3%80%81CMU%E3%80%81ADC%E3%80%81CTU%E3%80%81PWM%20%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81CMU%20%E3%81%AE%E3%81%BF%E3%81%8C%E3%82%BD%E3%83%95%E3%83%88%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%BD%E3%83%95%E3%83%88%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%AA%E3%81%9C%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
