MPC56XX link error
MPC56XX link error
2,375 次查看
384753860
IDE is codewarrior 10.5.  Processor is MPC5644A.
Errors(3 item)
Linked failed.
Linker command faile output section '.ivor_branch_table' has a type or input which is incompatible with section '.ivor_branch_table' in file 'C:\workspace\w20\FLASH\ivor_branch_table_c.obj'. Change the type or add an input for this.
mingw32-make:***[w20_prj.elf] Error 1
Wating for ideas.
Thank you very much.
标记 (2)
2,014 次查看
stanish
2,028 次查看
lizhichaosdut
I met thesame error,how to solve this ?
