MPC5646 Reference Design
3,253 次查看
tbonkers
I am looking for reference PCB design and minimal application circuit for MPC5646, 256 MAPBGA package.
3,182 次查看
davidtosenovjan
This is not evaluation board, but set of tools/adapters used for device calibration.
I have understood you are looking for low cost EVB, correct? If yes, this is not what you are looking for.
I am apologizing for previous links. By mistake I sent links to different family tools (MPC5746C instead of MPC5646C).
Here you may find EVB related to MPC5746C :
https://www.nxp.com/design/development-boards/automotive-development-platforms/mpc56xx-mcu-platforms...
On the bottom of the page, you may find mini-modules schematics, they are able to work independently to motherboard. No other low cost EVB exists.
4 回复数
3,235 次查看
tbonkers
Thank you for the quick response. The hardware design guide PDF is great. I was also looking at this board adapter - can I find its schematics and gerber files?
3,183 次查看
davidtosenovjan
3,238 次查看
davidtosenovjan
I could recommend to see following evaluation tools schematics, you can download in section ‘Design Resources’, potentially we can provide other design resources on demand (gerbers, etc.):
https://www.nxp.com/products/processors-and-microcontrollers/power-architecture/mpc5xxx-microcontrol...
Here you may find HW design guide:
https://www.nxp.com/webapp/Download?colCode=AN5220&location=null
3,214 次查看
tbonkers
Is it possible to download the schematics for the above mentioned adapter board?
