MPC5643L guide to flash bootloader (rba file)
1,064件の閲覧回数
pramod_wickr
I have the TRK USB MPC5643L kit, currently I am using Matlab and the MCT blockset to generate code to program the Micro controller. Normally i build the program (without download) and generate elf file, then use code warrior 10.7 to download to MCU (this is ok and it works).
However I want directly download code to MCU from matlab, I searched on this community and found that you have to load rba file into MCU first and configure MCU pins for boot ? (I'm not sure exactly ).
Can anyone please give a complete guide on how to load rba file and how to configure the pins?
Any help would be much appreciated Thank you :smileyhappy: :smileyhappy:
0 返答(返信)
