MPC5643L Test flash memory
2,440件の閲覧回数
Pat
Do you have an example or real values for the fields PART ID 1 H/L and PART ID2  of the Test flash memory of MPC5643L  ?
RM rev10 :
My Current Test flash memory values :
Pat
タグ(2)
2 返答(返信)
2,338件の閲覧回数
davidtosenovjan
Hi, I would guess it is only related to KGD (Known Good Die). As all KGD references has been removed, apparently it is not a option and these field don't need to be programmed in the factory.
2,338件の閲覧回数
Pat
Hi davidtosenovjan‌,
So, these fields should be also removed from the last MPC5643LRM  Rev10, Table 23-24. Test flash information.
Thank you.
BR,
Pat
