MPC5604s supervisor mode
3,133件の閲覧回数
mhogun
Hi All,
I am trying to set D_FLASH bit in the Functional Event Reset Disable Register (RGM_FERD),but the value is not reflecting in the register .
In datasheet it is mentioned as ,
It can be accessed in read/write in either supervisor mode or test mode.It can be accessed in read only in user mode.
I want to  generate  an interrupt request when a code or data flash fatal error occurs
Please guide me to resolve the above issues.
タグ(1)
6 返答(返信)
2,728件の閲覧回数
davidtosenovjan
Hi, this bit is read only (W field is grey) as you can see in the screenshot below:
It means you cannot generate interrupt in this case and device always will be reset.
2,728件の閲覧回数
mhogun
Thanks David.
I have another question to ask.
I am trying to set D_CMU0_FHL bit in the Functional Event Reset Disable Register (RGM_FERD),but the value is not reflecting in the register .
I want to  generate  an interrupt request when a clock frequency higher/lower than reference.
How to enter into supervisor or test mode in mpc5604s .
2,728件の閲覧回数
davidtosenovjan
Switching between supervisor/user mode I have described here, but I don't think it is the reason of your issue:
https://community.nxp.com/thread/358090
2,728件の閲覧回数
davidtosenovjan
"Each byte can be written only once after power-on reset."
I have just tried to modify the bit immediately after Power-on-reset and I was capable to modify register content.
2,728件の閲覧回数
mhogun
I have tried to modify the register but it was not happening. Whether we need to modify the register in startup code ?
Can u please share the code which you have used to change the  register?
Thank you in advance.
2,728件の閲覧回数
mhogun
Hi David,
