MPC5604P code flash read protected
2,265 次查看
Sanddy_TTL
 hello:
         how can i config protected code flash? can not be read code flash, it can protected my code . have example code to read code flash protected config?
标记 (1)
2,163 次查看
Sanddy_TTL
5 回复数
2,243 次查看
petervlna
To protect the flash you will use Censorship feature.
A password mechanism is designed to grant the legitimate user access to the non-volatile memory.
Please refer to detailed procedure described in Reference manual: 34.7 Censorship
Here is the example for Lauterbach debugger for censoring and uncensoring uC.
Peter
2,231 次查看
Sanddy_TTL
have write Shadow block code example?
*(uint32_t *) 0x00203DD8 = 0xBABADEDA;
*(uint32_t *) 0x00203DDC = 0xAABBCCDD;
*(uint32_t *) 0x00203DE0 = 0x55AA1111;
*(uint32_t *) 0x00203DE4 = 0x55AA1111;
this way can not effect。i can not write in.
2,224 次查看
petervlna
I am not familiar with your application, but hopefully you are not executing programming routine from flash:
  1. Understand the Shadow Flash Layout:
    • The censorship configuration is stored in Flash Block 0, specifically in the shadow row.
    • This includes the Censor Control Word (CWORD) and Censor Passwords.
  2. Prepare Your Application to Run from RAM:
    • You cannot execute code from flash while modifying flash (including shadow flash).
    • Copy the censorship routine to RAM and execute it from there.
    • Use a linker script to place the function in a .ramfunc section.
Peter
2,171 次查看
Sanddy_TTL
hello
my code in the ram to run, i don,t know how to write data to shadow block. how to config can write data to shadow block?
2,164 次查看
Sanddy_TTL
%3CLINGO-SUB%20id%3D%22lingo-sub-2139816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC5604P%20%E4%BB%A3%E7%A0%81%E9%97%AA%E5%AD%98%E8%AF%BB%E5%8F%96%E5%8F%97%E4%BF%9D%E6%8A%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%E5%8F%97%E4%BF%9D%E6%8A%A4%E4%BB%A3%E7%A0%81%E9%97%AA%E5%AD%98%EF%BC%9F%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E9%97%AA%E5%AD%98%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E4%BF%9D%E6%8A%A4%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%E6%98%AF%E5%90%A6%E6%9C%89%E8%AF%BB%E5%8F%96%E4%BB%A3%E7%A0%81%E9%97%AA%E5%AD%98%E4%BF%9D%E6%8A%A4%E9%85%8D%E7%BD%AE%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2141194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5604P%20code%20flash%20read%20protected%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx-Knowledge-Base%2FExample-MPC5604B-Shadow-Flash-Reprogramming%2Fta-p%2F1119903%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx-Knowledge-Base%2FExample-MPC5604B-Shadow-Flash-Reprogramming%2Fta-p%2F1119903%3C%2FA%3E%3CBR%20%2F%3E%E6%88%91%E5%8F%91%E7%8E%B0%E8%BF%99%E4%B8%AA%E4%BE%8B%E5%AD%90%E5%8F%AF%E4%BB%A5%E5%86%99%E9%98%B4%E5%BD%B1%E5%9D%97%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2141185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5604P%20code%20flash%20read%20protected%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%3CBR%20%2F%3E%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E5%9C%A8%20ram%20%E4%B8%AD%E8%BF%90%E8%A1%8C%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E9%98%B4%E5%BD%B1%E5%9D%97%E3%80%82%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E9%98%B4%E5%BD%B1%E5%9D%97%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5604P%20code%20flash%20read%20protected%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%B8%8D%E7%86%9F%E6%82%89%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E5%B8%8C%E6%9C%9B%E6%82%A8%E4%B8%8D%E6%98%AF%E5%9C%A8%E6%89%A7%E8%A1%8C%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%E7%BC%96%E7%A8%8B%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3E%E4%BA%86%E8%A7%A3%E9%98%B4%E5%BD%B1%20Flash%20%E5%B8%83%E5%B1%80%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%AE%A1%E6%9F%A5%E9%85%8D%E7%BD%AE%E5%AD%98%E5%82%A8%E5%9C%A8%E9%97%AA%E5%AD%98%E5%9D%97%200%20%E4%B8%AD%EF%BC%8C%E7%89%B9%E5%88%AB%E6%98%AF%E9%98%B4%E5%BD%B1%E8%A1%8C%E4%B8%AD%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E8%BF%99%E5%8C%85%E6%8B%AC%E6%A3%80%E6%9F%A5%E5%91%98%E6%8E%A7%E5%88%B6%E5%AD%97%20(CWORD)%20%E5%92%8C%E6%A3%80%E6%9F%A5%E5%91%98%E5%AF%86%E7%A0%81%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E5%87%86%E5%A4%87%E4%BB%8E%20RAM%20%E8%BF%90%E8%A1%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%9C%A8%E4%BF%AE%E6%94%B9%E9%97%AA%E5%AD%98%EF%BC%88%E5%8C%85%E6%8B%AC%E9%98%B4%E5%BD%B1%E9%97%AA%E5%AD%98%EF%BC%89%E6%97%B6%EF%BC%8C%E4%B8%8D%E8%83%BD%E6%89%A7%E8%A1%8C%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E5%B0%86%E5%AE%A1%E6%9F%A5%E4%BE%8B%E7%A8%8B%E5%A4%8D%E5%88%B6%E5%88%B0%20RAM%20%E4%B8%AD%EF%BC%8C%E7%84%B6%E5%90%8E%E5%9C%A8%20RAM%20%E4%B8%AD%E6%89%A7%E8%A1%8C%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E4%BD%BF%E7%94%A8%E9%93%BE%E6%8E%A5%E5%99%A8%E8%84%9A%E6%9C%AC%E5%B0%86%E5%87%BD%E6%95%B0%E6%94%BE%E5%85%A5%20.ramfunc%20%E9%83%A8%E5%88%86%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5604P%20code%20flash%20read%20protected%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ehave%20write%20Shadow%20block%20code%20example%3F%3CBR%20%2F%3E*(uint32_t%20*)%200x00203DD8%20%3D%200xBABADEDA%3B%3CBR%20%2F%3E*(uint32_t%20*)%200x00203DDC%20%3D%200xAABBCCDD%EF%BC%9B%3CBR%20%2F%3E*(uint32_t%20*)%200x00203DE0%20%3D%200x55AA1111%3B%3CBR%20%2F%3E*(uint32_t%20*)%200x00203DE4%20%3D%200x55AA1111%3B%3CBR%20%2F%3E%E8%BF%99%E7%A7%8D%E6%96%B9%E5%BC%8F%E6%97%A0%E6%B3%95%E7%94%9F%E6%95%88%E3%80%82%E6%88%91%E6%97%A0%E6%B3%95%E5%86%99%E5%85%A5%E3%80%82%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPC5604P%20code%20flash%20read%20protected%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E4%BF%9D%E6%8A%A4%E9%97%AA%E5%85%89%E7%81%AF%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20%22%E5%AE%A1%E6%9F%A5%20%22%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AF%86%E7%A0%81%E6%9C%BA%E5%88%B6%E6%97%A8%E5%9C%A8%E6%8E%88%E4%BA%88%E5%90%88%E6%B3%95%E7%94%A8%E6%88%B7%E8%AE%BF%E9%97%AE%E9%9D%9E%E6%98%93%E5%A4%B1%E6%80%A7%E5%AD%98%E5%82%A8%E5%99%A8%E7%9A%84%E6%9D%83%E9%99%90%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E6%8F%8F%E8%BF%B0%E7%9A%84%E8%AF%A6%E7%BB%86%E7%A8%8B%E5%BA%8F%EF%BC%9A34.7%20%E5%AE%A1%E6%9F%A5%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1753354109120.png%22%20style%3D%22width%3A%20541px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1753354109120.png%22%20style%3D%22width%3A%20541px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F349313i46164D344DDD006C%2Fimage-dimensions%2F541x257%3Fv%3Dv2%22%20width%3D%22541%22%20height%3D%22257%22%20role%3D%22button%22%20title%3D%22petervlna_0-1753354109120.png%22%20alt%3D%22petervlna_0-1753354109120.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E5%8A%B3%E7%89%B9%E5%B7%B4%E8%B5%AB%E8%B0%83%E8%AF%95%E5%99%A8%E5%AE%A1%E6%9F%A5%E5%92%8C%E5%8F%96%E6%B6%88%E5%AE%A1%E6%9F%A5%20uC%20%E7%9A%84%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EPeter%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
