MPC5604 DSPI  TX/RX FIFO queue bytes size?
2,768 次查看
Zhimin
Dear Team:
TKS
Atom
标签 (1)
5 回复数
2,635 次查看
PetrS
Which device did you mean?
There is 4-deep TX/RX FIFO on the MPC5604B and 5-deep TX/RX FIFO on the MPC5604P, MPC5604E.
BR, Petr
2,635 次查看
Zhimin
hi,jive!
can read PC14 input level when config this pin as SPI1 MISO (my target iic is MPC5604B)?
2,635 次查看
PetrS
the PC14 cannot be set as SPI1 MISO, did you mean PC4?
For the PC4 if SIU.PCR[36]. IBE bit is set you can read the input level from SIU.GPDI[36] register too.
BR, Petr
2,635 次查看
Zhimin
TKS!
2,635 次查看
Zhimin
MPC5604B
