MPC555 : FLASH program GMD driver : source code
3,116 次查看
Lucd
According to CDR_AR_600 of MPC555.K3_05K83H errata, the version 6.1 of the GMD internal FLASH driver programming algorithm shall be used.
I have found this driver in the net but the source code is not available.
Is there a mean to get this source code ?
Thank you
Luc
3,108 次查看
lukaszadrapa
Hi Luc,
unfortunately the source files are not available.
Just in case, I'm attaching here installation package General Market CMF Driver V3.0.3.
This is the latest one and it is the right one according to CDR_AR_600.
Lukas
3,109 次查看
lukaszadrapa
Hi Luc,
Lukas
3,081 次查看
Lucd
Hi Lukas,
Thank you for your reply.
Luc
