MCan Configuration on 577x
已解决
跳至解决方案
2,176 次查看
sugab
Hi all,
Sorry, i am new to this implementation,
i would like to configure MCAN on 5775b, and i dont use FIFO on Mcan and set Rx = 12 and TX = 24
so i assume, all mailboxes will reserve 1 can_id
My question is, is the TX and RX sharing the mailbox indexes?
like mailbox 0-12 will be RX and 13-36 will be RX
or RX mailbox will be 0-12 and TX will be 0-24?
thank you very much
really appreciate
标记 (2)
1 解答
2,164 次查看
PetrS
mailbox indexes are not shared.
So indexes for RX mailbox will be 0-11 and TX will be 0-23.
BR, Petr
在原帖中查看解决方案
2 回复数
2,152 次查看
sugab
Hi Petrs
thank you for your explanation
br
sugab,
2,165 次查看
PetrS
BR, Petr
