LIN implementation
LIN implementation
8,233件の閲覧回数
akhilk234
I am trying to implement LIN driver for MPC5777C-DEVB. I'm able to transmit the complete LIN frame but I'm also receiving random data if I clear the eSCI_IFSR2_TXRDY register before updating the eSCI_LTR register. If I don't clear the eSCI_IFSR2_TXRDY register before updating the eSCI_LTR register then I'm getting complete LIN frame and in-between LIN frames I'm receiving PID field and data frames in sci data format. How can I avoid these unwanted messages in between LIN frames. These CRO snap shots I'm attaching. And all esci registers screen shot I'm attaching.
2 返答(返信)
8,218件の閲覧回数
PetrS
what is the code you have? And what LIN slave is connected?
Attached is very simple code showing LIN TX and RX operation.
BR, Petr
8,202件の閲覧回数
akhilk234
I didn't connected any slave and I am observing on CRO and Kvaser Leaf Professional LIN. I haven't updated CSE bit that's why I received 2 LIN Frames. Now I'm getting proper LIN Frame.
But I want to use MPC5777C in LIN Slave mode. How can I uses this board in LIN Slave mode? What are the registers should I update to put this board in LIN Slave mode?
