Thanks for your attention ,the problem still remains, Linux Kernel booting up log is as follows:
U-Boot 2016.09-svn136 (Nov 13 2020 - 01:16:21 -0800)
CPU0: T2080, Version: 1.1, (0x85300011)
Core: e6500, Version: 2.0, (0x80400120)
Clock Configuration:
CPU0:1799.820 MHz, CPU1:1799.820 MHz, CPU2:1799.820 MHz, CPU3:1799.820 MHz,
CCB:599.940 MHz,
DDR:933.310 MHz (1866.620 MT/s data rate) (Asynchronous), IFC:599.940 MHz
FMAN1: 699.930 MHz
QMAN: 299.970 MHz
PME: 599.940 MHz
L1: D-cache 32 KiB enabled
I-cache 32 KiB enabled
Reset Configuration Word (RCW):
00000000: 1207001b 15000000 00000000 00000000
00000010: de2d0002 0090ac00 68185000 c1000000
00000020: 00800000 00000000 00000000 00028d3c
00000030: 00000014 02800009 00000000 00000004
Board: T2080RDB, Board rev: 1.0 boot from SD/MMC
SERDES Reference Clocks:
SD1_CLK1=100MHz, SD1_CLK2=100MHz
SD2_CLK1=100MHz, SD2_CLK2=100MHz
I2C: ready
SPI: ready
DRAM: 2 GiB (DDR3, 64-bit, CL=13, ECC off)
VID: Could not find voltage regulator on I2C.
Warning: Adjusting core voltage failed.
Flash: 0 Bytes
L2: 2 MiB enabled
Corenet Platform Cache: 512 KiB enabled
Using SERDES1 Protocol: 222 (0xde)
Using SERDES2 Protocol: 45 (0x2d)
SRIO1: enabled
SRIO2: enabled
NAND: 512 MiB
MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: Reset Ethernet PHY
MMC read: dev # 0, block # 5120 CONFIG_SYS_FMAN_FW_ADDR : 280000, count 128 ...
Fman1: Uploading microcode version 106.4.18
[FSL_MDIO0]search phy addr=0 phy_id=221622 r=0
[FSL_MDIO0]find phy addr=0 phy_id=221622
[FSL_MDIO0]search phy addr=1 phy_id=221622 r=0
[FSL_MDIO0]find phy addr=1 phy_id=221622
FM1@DTSEC3 [PRIME], FM1@DTSEC4
Hit any key to stop autoboot: 0
xt202 # run ramboot
FM1@DTSEC3 Waiting for PHY auto negotiation to complete.... TIMEOUT !
FM1@DTSEC3: Could not initialize
Using FM1@DTSEC4 device
TFTP from server 192.168.3.40; our IP address is 192.168.3.131
Filename 'uImage'.
Load address: 0x1000000
Loading: sending ARP for 192.168.3.40
6.9 MiB/s
done
Bytes transferred = 4945096 (4b74c8 hex)
Filename 'devicetree.dtb'.
Load address: 0xc00000
2.1 MiB/s
done
Bytes transferred = 30857 (7889 hex)
Filename 'uramdisk.image.gz'.
Load address: 0x2000000
7 MiB/s
done
Bytes transferred = 15799625 (f11549 hex)
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 01000000 ...
Image Name: Linux-4.1.35-rt41+
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 4945032 Bytes = 4.7 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 02000000 ...
Image Name: uboot ext2 ramdisk rootfs
Image Type: PowerPC Linux RAMDisk Image (gzip compressed)
Data Size: 15799561 Bytes = 15.1 MiB
## Flattened Device Tree blob at 00c00000
Booting using the fdt blob at 0xc00000
Uncompressing Kernel Image ... OK
Loading Device Tree to 03fe5000, end 03fff888 ... OK
Reserved memory: initialized node bman-fbpr, compatible id fsl,bman-fbpr
Reserved memory: initialized node qman-fqd, compatible id fsl,qman-fqd
Reserved memory: initialized node qman-pfdr, compatible id fsl,qman-pfdr
Reserved memory: initialized node pme-pdsr, compatible id fsl,pme-pdsr
Reserved memory: initialized node pme-sre, compatible id fsl,pme-sre
Reserved memory: initialized node usdpaa_mem, compatible id fsl,usdpaa-mem
Using CoreNet Generic machine description
MMU: Supported page sizes
4 KB as direct
2048 KB as direct & indirect
4096 KB as direct
16384 KB as direct
65536 KB as direct
262144 KB as direct
1048576 KB as direct
MMU: Book3E HW tablewalk enabled
Found initrd at 0xc000000002000040:0xc000000002f11549
bootconsole [udbg0] enabled
CPU maps initialized for 2 threads per core
Starting Linux PPC64 #97 SMP Sun Nov 22 23:15:53 PST 2020
ppc64_pft_size = 0x0
phys_mem_size = 0x80000000
dcache_line_size = 0x40
icache_line_size = 0x40
cpu_features = 0x00180480581802c8
possible = 0x00180480581802c8
always = 0x00180400581802c0
cpu_user_features = 0xdc008000 0x08000000
mmu_features = 0x000a0010
firmware_features = 0x0000000000000000
<- setup_system()
Linux version 4.1.35-rt41+ (coresat@ubuntu) (gcc version 4.9.2 (GCC) ) #97 SMP Sun Nov 22 23:15:53 PST 2020
CoreNet Generic board
Zone ranges:
DMA [mem 0x0000000000000000-0x000000007fffffff]
DMA32 empty
Normal empty
Movable zone start for each node
Early memory node ranges
node 0: [mem 0x0000000000000000-0x000000007fffffff]
Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
MMU: Allocated 2112 bytes of context maps for 255 contexts
PERCPU: Embedded 17 pages/cpu @c00000007fd00000 s28760 r0 d40872 u131072
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 517120
Kernel command line: root=/dev/ram rw console=ttyS1,115200
log_buf_len individual max cpu contribution: 4096 bytes
log_buf_len total cpu_extra contributions: 28672 bytes
log_buf_len min size: 16384 bytes
log_buf_len: 65536 bytes
early log buf free: 12428(75%)
PID hash table entries: 4096 (order: 3, 32768 bytes)
Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Sorting __ex_table...
Memory: 1623236K/2097152K available (7836K kernel code, 1092K rwdata, 2840K rodata, 360K init, 763K bss, 473916K reserved, 0K cma-reserved)
Hierarchical RCU implementation.
RCU debugfs-based tracing is enabled.
CONFIG_RCU_FANOUT set to non-default value of 32
Additional per-CPU info printed with stalls.
RCU restricting CPUs from NR_CPUS=24 to nr_cpu_ids=8.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
NR_IRQS:512 nr_irqs:512 16
mpic: Setting up MPIC " OpenPIC " version 1.2 at ffe040000, max 8 CPUs
mpic: ISU size: 512, shift: 9, mask: 1ff
mpic: Initializing for 512 sources
clocksource timebase: mask: 0xffffffffffffffff max_cycles: 0x8a5d528ca, max_idle_ns: 440795203517 ns
clocksource: timebase mult[1aab5972] shift[24] registered
Console: colour dummy device 80x25
Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
e6500 family performance monitor hardware support registered
Brought up 8 CPUs
devtmpfs: initialized
clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
xor: measuring software checksum speed
8regs : 3561.000 MB/sec
8regs_prefetch: 3187.000 MB/sec
32regs : 3288.000 MB/sec
32regs_prefetch: 2651.000 MB/sec
altivec : 5406.000 MB/sec
xor: using function: altivec (5406.000 MB/sec)
Bman ver:0a02,02,01
qman-fqd addr 0x000000007f000000 size 0x800000
qman-pfdr addr 0x000000007c000000 size 0x2000000
Qman ver:0a01,03,01,02
Machine: fsl,T2080RDB
SoC family: QorIQ T2080
SoC ID: svr:0x85300011, Revision: 1.1
PCI: Probing PCI hardware
raid6: altivecx1 gen() 1071 MB/s
raid6: altivecx2 gen() 1916 MB/s
raid6: altivecx4 gen() 3059 MB/s
raid6: altivecx8 gen() 3208 MB/s
raid6: int64x1 gen() 541 MB/s
raid6: int64x1 xor() 729 MB/s
raid6: int64x2 gen() 911 MB/s
raid6: int64x2 xor() 930 MB/s
raid6: int64x4 gen() 1302 MB/s
raid6: int64x4 xor() 983 MB/s
raid6: int64x8 gen() 1253 MB/s
raid6: int64x8 xor() 857 MB/s
raid6: using algorithm altivecx8 gen() 3208 MB/s
raid6: using intx1 recovery algorithm
vgaarb: loaded
SCSI subsystem initialized
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
bman-fbpr addr 0x000000007e000000 size 0x1000000
Bman err interrupt handler present
Bman portal initialised, cpu 0
Bman portal initialised, cpu 1
Bman portal initialised, cpu 2
Bman portal initialised, cpu 3
Bman portal initialised, cpu 4
Bman portal initialised, cpu 5
Bman portal initialised, cpu 6
Bman portal initialised, cpu 7
Bman portals initialised
Qman err interrupt handler present
QMan: Allocated lookup table at 8000000000002000, entry count 131073
Qman portal initialised, cpu 0
Qman portal initialised, cpu 1
Qman portal initialised, cpu 2
Qman portal initialised, cpu 3
Qman portal initialised, cpu 4
Qman portal initialised, cpu 5
Qman portal initialised, cpu 6
Qman portal initialised, cpu 7
Qman portals initialised
Bman: BPID allocator includes range 32:32
Qman: FQID allocator includes range 256:512
Qman: FQID allocator includes range 32768:32768
Qman: CGRID allocator includes range 0:256
Qman: pool channel allocator includes range 1025:15
USDPAA region at 60000000:10000000(60000:10000), 1 TLB1 entries)
fsl-ifc ffe124000.localbus: Freescale Integrated Flash Controller
fsl-ifc ffe124000.localbus: IFC version 1.3, 8 banks
Switched to clocksource timebase
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
UDP hash table entries: 1024 (order: 3, 32768 bytes)
UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 15424K (c000000002001000 - c000000002f11000)
futex hash table entries: 2048 (order: 5, 131072 bytes)
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(1.380:1): initialized
HugeTLB registered 4 MB page size, pre-allocated 0 pages
HugeTLB registered 16 MB page size, pre-allocated 0 pages
HugeTLB registered 64 MB page size, pre-allocated 0 pages
HugeTLB registered 256 MB page size, pre-allocated 0 pages
HugeTLB registered 1 GB page size, pre-allocated 0 pages
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
ntfs: driver 2.1.32 [Flags: R/O].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
async_tx: api initialized (async)
io scheduler noop registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0xffe11c500 (irq = 36, base_baud = 18748125) is a 16550A
console [ttyS1] disabled
serial8250.0: ttyS1 at MMIO 0xffe11c600 (irq = 36, base_baud = 18748125) is a 16550A
console [ttyS1] enabled
bootconsole [udbg0] disabled
ePAPR hypervisor byte channel driver
bootcfg_partition.220 msdos magic check failed
brd: module loaded
loop: module loaded
st: Version 20101219, fixed bufsize 32768, s/g segs 256
fsl_espi ffe110000.spi: cs=0, init_csmode=0x100008
m25p80 spi32766.0: unrecognized JEDEC id bytes: ff, ff, ff
fsl_espi ffe110000.spi: at 0x800008008095e000 (irq = 53)
libphy: Fixed MDIO Bus: probed
libphy: Freescale XGMAC MDIO Bus: probed
Freescale FM module, FMD API version 21.1.0
Freescale FM Ports module
fsl_mac: mac.c:458:mac_load() fsl_mac: FSL FMan MAC API based driver
fsl_mac ffe4e4000.ethernet: FMan MEMAC
fsl_mac ffe4e4000.ethernet: FMan MAC address: 00:11:22:88:86:02
fsl_mac ffe4e6000.ethernet: FMan MEMAC
fsl_mac ffe4e6000.ethernet: FMan MAC address: 00:11:22:88:86:08
fsl_mac ffe4ea000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@ea000) failed
fsl_mac: probe of ffe4ea000.ethernet failed with error -22
fsl_dpa: dpaa_eth.c:1163:dpa_load() FSL DPAA Ethernet driver
fsl_dpa: dpaa_eth.c:1089:dpaa_eth_priv_probe() fsl_dpa: Probed interface eth0
fsl_dpa: dpaa_eth.c:1089:dpaa_eth_priv_probe() fsl_dpa: Probed interface eth1
fsl_advanced: dpaa_eth_base.c:251:dpa_advanced_load() FSL DPAA Advanced drivers:
fsl_proxy: dpaa_eth_proxy.c:354:dpa_proxy_load() FSL DPAA Proxy initialization driver
fsl_dpa_shared: dpaa_eth_shared.c:885:dpa_shared_load() FSL DPAA Shared Ethernet driver
fsl_dpa_macless: dpaa_eth_macless.c:469:dpa_macless_load() FSL DPAA MACless Ethernet driver
fsl_oh: offline_port.c:823:oh_port_load() FSL FMan Offline Parsing port driver
fsl-of-dma ffe100300.dma: dma channel dma-uio0-0 initialized
fsl-of-dma ffe100300.dma: dma channel dma-uio0-1 initialized
fsl-of-dma ffe100300.dma: dma channel dma-uio0-2 initialized
fsl-of-dma ffe100300.dma: dma channel dma-uio0-3 initialized
fsl-of-dma ffe100300.dma: dma channel dma-uio0-4 initialized
fsl-of-dma ffe100300.dma: dma channel dma-uio0-5 initialized
fsl-of-dma ffe100300.dma: dma channel dma-uio0-6 initialized
fsl-of-dma ffe100300.dma: dma channel dma-uio0-7 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-0 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-1 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-2 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-3 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-4 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-5 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-6 initialized
fsl-of-dma ffe101300.dma: dma channel dma-uio1-7 initialized
srio_port->mem_win=80b80000,srio_port->res->start=20000000
fsl-of-srio ffe0c0000.rapidio: Rapidio UIO driver initialized
i2c /dev entries driver
mpc-i2c ffe118000.i2c: timeout 1000000 us
rtc-ds1307 0-0068: rtc core: registered ds1339 as rtc0
mpc-i2c ffe119000.i2c: timeout 1000000 us
booke_wdt: powerpc book-e watchdog driver loaded
md: raid6 personality registered for level 6
md: raid5 personality registered for level 5
md: raid4 personality registered for level 4
Freescale(R) MPC85xx EDAC driver, (C) 2006 Montavista Software
mpc85xx_mc_err_probe: No ECC DIMMs discovered
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc ffe114000.sdhc: No vmmc regulator found
sdhci-esdhc ffe114000.sdhc: No vqmmc regulator found
mmc0: SDHCI controller on ffe114000.sdhc [ffe114000.sdhc] using ADMA 64-bit
fsl-of-rman ffe1e0000.rman: Of-device /soc@ffe000000/rman@1e0000 initialized
fsl-of-rman ffe1e0000.rman: RMan inbound block0 initialized.
fsl-of-rman ffe1e0000.rman: RMan inbound block1 initialized.
fsl-of-rman ffe1e0000.rman: RMan inbound block2 initialized.
fsl-of-rman ffe1e0000.rman: RMan inbound block3 initialized.
Freescale USDPAA process driver
Freescale USDPAA process IRQ driver
dce_sys_init done!
fsl-dce ffe312000.dce: Device /soc@ffe000000/dce@312000 initialized ver: 0x0af00101
fsl-pme ffe316000.pme: ver: 0x00100201
Freescale pme2 db driver
Freescale pme2 scan driver
fsl-pme2-scan: device pme_scan registered
Freescale hypervisor management driver
fsl-hv: no hypervisor found
ipip: IPv4 over IPv4 tunneling driver
Initializing XFRM netlink socket
NET: Registered protocol family 10
mmc0: MAN_BKOPS_EN bit is not set
sit: IPv6 over IPv4 tunneling driver
mmc0: new high speed MMC card at address 0001
mmcblk0: mmc0:0001 P1XXXX 7.20 GiB
mmcblk0boot0: mmc0:0001 P1XXXX partition 1 2.00 MiB
mmcblk0boot1: mmc0:0001 P1XXXX partition 2 2.00 MiB
mmcblk0rpmb: mmc0:0001 P1XXXX partition 3 128 KiB
mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
NET: Registered protocol family 15
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
fsl_generic: FSL DPAA Generic Ethernet driver
rtc-ds1307 0-0068: setting system clock to 2000-01-03 05:31:36 UTC (946877496)
md: Skipping autodetection of RAID arrays. (raid=autodetect will force)
RAMDISK: gzip image found at block 0
VFS: Mounted root (ext2 filesystem) on device 1:0.
devtmpfs: mounted
Freeing unused kernel memory: 360K (c000000000a74000 - c000000000ace000)
bootcfg_flashtype.53 get key[flashtype] failed
partition_load.60 unknown flash
partition_load.65 partition_load failed
bootcfg_paramter_load.323 unknown flash type[0xff]
parameter_loadfile.53 fopen /etc/parameter/oem.json failed
bootcfg_load.286 unknown flash
bootcfg_check.10 bootcfg_load failed
Please press Enter to activate this console.
XT202 login:
XT202 login:
XT202 login: root
Password:
Processing /etc/profile... Done
[root@XT202 ~]#random: nonblocking pool is initialized
[root@XT202 tmp]#./sra
sra>
sra> sra -test srio port1 dma swrite 16
Port 1 : dma task creating successed!
-- srio_type:SWRITE; payload_size:16; data:0x5a
sra> ./sra: fsl_dma_wait(): dma transfer regs->sr=80: Device or resource busy
port 1: dma task error!
