Is there an FTP server for LWIP
MattJCole
Contributor V
The KSDK came with an FTP server but now I am using the LWIP in the S32 SDK and I still need an FTP server. Is there FTP server code that works with the LWIP?
lukaszadrapa
MattJCole
Contributor V
Thanks that helped a lot. I was having trouble with opening and closing the data connection. The code you sent showed which LWIP interface I should use.
MattJCole
Contributor V
Thanks. I will try the code you sent and let you know how it turns out.
MattJCole
Contributor V
I found this that mentions FTP server with LWIP and FreeRTOS but can not find the code. Do you know where the code is?
FTP Server Using MCF51CN Family and FreeRTOS (nxp.com)
lukaszadrapa
The zip package can be downloaded here:
https://www.nxp.com/docs/en/application-note-software/AN3931SW.zip
Lukas
Moajiz
I have gone through the FTP server example in the provided link to the code, The library is quite simple and easy to implement. However, there is no secure layer (SSL/TLS) available on top of the FTP.
Is there an updated FTP server/client library is available with integrated SSL/TLS support? I am in urgent need of implementing the FTP in my ongoing project, Any support from the community will be highly valuable for me.
Thanks in advance.
lukaszadrapa
Hello Matt,
LWIP stack contains TFTP (Trivial FTP) but we do not have sample code for this.
Lukas
