Interrupts whit MPC5634
1,858 次查看
waltercolombo
I'm starting with the MPC5634, my current question:
how to make an input pin of eTPU2 generate an interrupt on the central core where I can insert e execute code?
标签 (1)
1 回复
1,607 次查看
PetrS
Are you asking how to emulate IRQ pins using eTPU?
Why you don’t use IRQ pins (using SIU)?
The eTPU can interrupt CPU only using eTPU microcode. You may use precompiled General Purpose Input/Output (GPIO) eTPU function; see http://www.freescale.com/files/online_tools/eTPU/GPIO.html
But the usage of IRQ on SIU is much simpler.
Petr
