Insert deadtime for PWM generated by eMIOS
676件の閲覧回数
EmilyZhou8
I am finding documents about inserting deadtime for PWM generated by eMIOS of MPC5XXX. I only found  the document AN4658 mentioning about PWM deadtime on page 10. Is there any document with demo about inserting deadtime for PWM using eMIOS?
Thank you very much!
Emily
660件の閲覧回数
petervlna
Please refer to the reference manual for dead time insertion in eMIOS channels:
For example in this mode:
Peter
4 返答(返信)
661件の閲覧回数
petervlna
Peter
652件の閲覧回数
EmilyZhou8
Hi Peter,
Thank you for your reply which helps a lot. I did successfully use OPWMC mode to generate PWM with dead time. But I don't understand why I should add "EMIOS.CH[1].CCR.B.UCPREN = 1; /* Enable prescaler; uses default divide by 1 */", or else PWM won't be generated. I attached my code blow.
Emily
629件の閲覧回数
petervlna
From reference manual:
So you clock to pwm is not generated in case it is 0.
Peter
625件の閲覧回数
EmilyZhou8
Thanks a lot
