MPC5604P DEBUG mode report an error
2,295 次查看
kabusiji
MCU:MPC5604P
IDE:codewarrier 5.9.0.PNG
debug mode Error:
As shown in the figure,When I enter debug mode, the status window will show error,What does this error mean and how can I fix it.Please help me, thank you!
5 回复数
2,276 次查看
petervlna
Either you do not have code loaded in the micro or you access to memories is restricted by some protection mechanism.
First make sure you code in micro properly loaded.
In memory view I do not see any data.
Peter
2,273 次查看
kabusiji
The code runs normally in the MCU, but cannot enter debug mode
2,250 次查看
petervlna
But from your screenshot I see your MCU is in debug mode. Status of debugger is ready and you are stopped at _start label. But on that address I see no code. So once you run or step code you will get illegal instruction exception.
What do you mean by runs normally? Is it spinning motor or blinking with LEDs or sending some commands on serial lines?
Peter
@stanish can you comment here?
2,192 次查看
stanish
This issue may occur when there is either a part of memory or a register that access the unmapped/unavailable memory.
I'd suggest closing all variable and memory debugger windows and restart the debug session.
  Hope it helps.
Stan
2,240 次查看
kabusiji
I don't know what's going on, but the debug mode works fine now, thank you very much for your reply
