In FreeRTOS, while executing the tasks, automatically it is going to WKPU ISR and remain in ISR only
priya_p
In FreeRTOS, I am using 2 tasks which need RTC. For 1st task it is executing smoothly, but for second task it is triggering WKPU ISR and stuck in ISR only. Why it is happening so?
PetrS
try if increasing heap will help.
BR, Petr
priya_p
already tried, still not working.
PetrS
ok, so can you share your project?
Br, Petr
priya_p
I am attaching the sd card code, here also WKPU interrupt is triggered. Not able to understand why it is triggering.
PetrS
seems it is because you call printf before start scheduler. Try to comment those 2 lines and print within tasks.
Br, Petr
priya_p
Tried that one but not at all working. The uploaded code is not running on FreeRTOS. It's a code without freeRTOS component.
PetrS
the project you shared above is using FreeRTOS, and it worked on my side after doing modification I wrote.
If have different project try to share it too.
BR, Petr
