How to change the CLUT while program is running. MPC5645S. DCU3.
fatsnyang
MPC5645S has 2048 entties which provides up to eight full CLUTs for 8 bpp layers.
But on my project, there are a lot of 8bpp images,so , 2048 enties is not enough to save all the CLUTs,
so, I must look for a solution to change the CLUT while the program is running.
I try to change CLUT when system change the Panel, but it is offen get a wrong CLUT data, beause images is looks bad(with wrong colors).
Appreciate for giving advice or reference code.
