How to build a CodeWarrior project using codes  generated by toolbox
2,541件の閲覧回数
hjhjhj
     I want to  build a MPC5643L CodeWarrior project using codes  generated by toolbox,   but there're some errors I never met .Can anybody give me some suggestions to configured the CodeWarrior project?
Thank you!
Hj
Original Attachment has been moved to: can_simple_block_rappid_rtw.rar
4 返答(返信)
2,310件の閲覧回数
petervlna
It would be really faster for you if you could specify the compiler errors here.
Peter
2,309件の閲覧回数
hjhjhj
Hi Peter,
     The attachment is the simulink model and the codes generated by the model.
Thank you !
Hj
2,309件の閲覧回数
martin_kovar
I posted you the answer in thread below:
https://community.nxp.com/thread/453687
Martin
2,309件の閲覧回数
petervlna
You are using BOOKE instructions in section which is targeted to be VLE.
Reword it to VLE or dissable VLE and leave them as BOOKE.
Peter
