How can I set dual conversion in ADC command list
2,010 次查看
alexanderhu
How can i initial the TCU?Is there any SW DEMO?
1,874 次查看
petervlna
I expect you are referring to CTU and not TCU as you are speaking about ADC command list.
Here is the explanation:
Select CMS and Channels which have to be converted in dual-conversion mode.
Make sure your ADC's are in CTU mode.
Peter
1,875 次查看
petervlna
Peter
1,874 次查看
alexanderhu
Thank you for your help,Pete.The datasheet(MPC5744PRM.pdf) is hard to read.
1,874 次查看
davidtosenovjan
Could you specify used device? Thanks
