Hex can't be changed when I change link file.
1,855件の閲覧回数
bwp530
MPC5777M  S32DS-2017R1
I make a simple project about Z4_2 of MPC5777M.
the default code addr in link file is 0x1000000 and I want to change to 0x1500000.
But in hex file, The data in 0xfc0004 have no change.
when I change the addr to 0x1500000, the addr 0xfc0004 is still 0x1000000.
タグ(3)
1,785件の閲覧回数
lukaszadrapa
I can see in the flashrchw.c that this value is hard-coded:
So, you need to update this file accordingly.
Hope this helps.
Lukas
2 返答(返信)
1,786件の閲覧回数
lukaszadrapa
Hope this helps.
Lukas
1,785件の閲覧回数
bwp530
thanks, it really helped me.
