GreenHills MULTI debugger + P&E usb-Multilink
kentlin
Debugging MPC574xP with
P&E Multilink + GreenHills debugger.
kentlin
Hi Ziwi,
What is your device?
as I know, the peserv supports the MPC574xP only.
Kent
ziwi
Hi, Lin,
We're using S32K144 family MCUs.
What's the version of MULTI debugger you're using?
Why there was a 'peserv' option in your MULTI debugger?
kentlin
Hi Ziwi,
Mine is MULTI IDE 6.1.6 for the Power Architecture.
your Multi should be for the ARM. That could be different.
It better to check that with GHS.
Kent
jackjack
where can i download MULTI IDE  for the Power Architecture. i couldn't find it in www.ghs.com.
i am using mpc5744P.
ziwi
GHS support told me that P&E debugger is not supported for S32K MCU in MULTI Debugger.
I really appreciate your help, thanks.
ziwi
Hi, Lin,
In Multi debugger, I didn't find P&E Cable( peserv) option.
Can you tell me how did you get 'peserv' option? Thanks.
hong_hong
Hi,ziwi:
I want use Multi to build a S32k146 Project with MCAL,Do you have the demo,Can you give me a help?
