Example ssdConfig for mpc5646b
2,526件の閲覧回数
vaso
Hello
Tell me how to implement the function of removing write protection of the high block in the MPC5646B processor. I took the example with MPC5602B as a basis, but I can only write to the lower part of the flash. How can I implement writing to the second bank of the flash. I am trying to use this code
where can I download an example example for MPC5646. All the links that are on the forum are empty. Or how can I correct my code for initializing the block. With the example below, I get error 300 when initializing the unlock
/* Unlock LOW PRIMARY blocks */
ret = pSetLock(&ssdDataConfig, LOCK_LOW_PRIMARY, 0x0U, FLASH_LMLR_PASSWORD);
ret |= pGetLock(&ssdDataConfig, LOCK_LOW_PRIMARY, &blkLockEnabled, &blkLockState);
blkLockState &= (0xFFFFFFFF >> (32 - ssdDataConfig.lowBlockNum));
if ((C90FL_OK != ret) || blkLockState)
ErrorTrap(ret);
/* Unlock LOW SECONDARY blocks */
ret = pSetLock(&ssdDataConfig, LOCK_LOW_SECONDARY, 0x0U, FLASH_SLMLR_PASSWORD);
ret |= pGetLock(&ssdDataConfig, LOCK_LOW_SECONDARY, &blkLockEnabled, &blkLockState);
ErrorTrap(ret);
/* Unlock HIGH blocks (optional) */
ret = pSetLock(&ssdDataConfig, LOCK_HIGH, 0x0U, FLASH_HBLR_PASSWORD);
ret |= pGetLock(&ssdDataConfig, LOCK_HIGH, &blkLockEnabled, &blkLockState);
blkLockState &= (0xFFFFFFFF >> (32 - ssdDataConfig.highBlockNum));
ErrorTrap(ret);
4 返答(返信)
2,232件の閲覧回数
petervlna
I was talking to one colleague and he have example code.
Hope it helps.
Peter
2,498件の閲覧回数
petervlna
Here are the examples:
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/MPC5-software-example-list/ta-p/1102445#MPC5646C
Access protections may be applied on a per-master basis for both reads and writes to support security and privilege mechanisms.
You need to unlock the HBL before programming:
/* unlock HLB block */
CFLASH.HLB.R =  0xB2B22222; /* unlock register */
CFLASH.HLB.R = 0x00000FFF; /* unlock all HLB flash */
Peter
2,483件の閲覧回数
vaso
From the link you provided, I do not see an example of programming via the SSD_C90FL driver for BANK2 starting at address 0x180000.
I am encountering a problem where, using the SSD_C90FL driver, I am unable to program flash memory above address 0x180000.
I tried changing the password, and when using an incorrect password, I receive error code A00. Now, the password is accepted (no error), but I get error code 200 during flash programming.
Can you provide me with a working example for MPC5646B using the SSD_C90FL driver, or at least confirm the correct block configuration for BANK2 in the SSD_CONFIG?
Below is the configuration I tried:
lowBlockNum = 12, .
idBlockNum = 4,
highBlockNum = 16,
Thank you!
2,412件の閲覧回数
vaso
I wanted to add more details to my original post in this thread about programming the second flash bank (high blocks / BANK2) on MPC5646B using the SSD_C90FL driver.
BANK1 can be programmed without issues using the standard SSD_C90FL example. For BANK2, however, I still cannot get a working ssd_config configuration or correct block masks.
What I have checked and tried so far:
According to the block map in the MPC5646B Reference Manual, BANK2 consists of high blocks.
I have attempted to determine the addresses and masks for FlashErase() and FlashProgram() experimentally, but no success so far.
Unlocking via FlashSetLock() for high blocks does not work — likely due to incorrect mask values or base address settings.
I would appreciate help with the following points:
The correct SSD_CONFIG structure settings for BANK2 (addresses, sizes, number of blocks).
Whether a separate base address is required for BANK2 or if it shares the same base as BANK1.
Correct mask values for lowBlockLock, midBlockLock, and highBlockLock when unlocking high blocks.
A working example of FlashErase() and FlashProgram() calls for BANK2 on MPC5646B.
If anyone can share a working code snippet (or a link to an application note/example) where BANK2 is covered in detail for MPC5646B, that would be very helpful.
Here is my current draft configuration and code skeleton for BANK2:
#include "ssd_types.h"
#include "ssd_c90fl.h" // Header name may vary depending on SSD package
/* ======== TODO: Replace with exact values from MPC5646B RM ======== */
/* Fill in:
- P-Flash base address (main array)
- BANK2 (high blocks) start address, block size, number of blocks
- Shadow/UTEST base (if required)
- Correct lock/select masks for high blocks
#define PFLASH_BASE 0x00XXXXXXu // TODO: base P-Flash address
#define BANK2_FIRST_BLOCK_ADDR 0x00YYYYYYu // TODO: start of first high block
#define BANK2_BLOCK_SIZE 0x00040000u // TODO: block size (e.g., 256KB)
#define BANK2_BLOCK_COUNT 0x00000004u // TODO: number of high blocks
#define DEMO_TARGET_ADDR (BANK2_FIRST_BLOCK_ADDR)
#define HIGH_BLOCK_SEL_MASK 0x00000001u // TODO: correct high block select mask
#define HIGH_BLOCK_LOCK_MASK 0x00000001u // TODO: correct high block lock mask
SSD_CONFIG ssdConfig = {
/* pFlashBase */ PFLASH_BASE,
/* uTestBase */ 0xXXXXXXu, // TODO: UTEST/shadow base (if required)
/* lowBlockNum */ 0,
/* midBlockNum */ 0,
/* highBlockNum */ BANK2_BLOCK_COUNT,
/* blockInfo */ NULL,
/* debugMode */ 0u,
/* callBack */ NULL
uint32_t demoBuf[64] = {0};
static void FillDemoBuffer(void)
for (uint32_t i = 0; i < (sizeof(demoBuf)/sizeof(demoBuf[0])); ++i) {
demoBuf[i] = 0xA5A50000u + i;
int ProgramBank2Demo(void)
uint32_t ret;
FLASH_SSD_CONFIG flashCfg = ssdConfig;
ret = FlashInit(&flashCfg);
if (ret != FTFx_OK) return ret;
ret = FlashSetLock(&flashCfg,
/* lowLock */ 0x00000000u,
/* midLock */ 0x00000000u,
/* highLock */ ~HIGH_BLOCK_LOCK_MASK);
ret = FlashBlockSelect(&flashCfg,
/* lowSel */ 0x00000000u,
/* midSel */ 0x00000000u,
/* highSel */ HIGH_BLOCK_SEL_MASK,
/* selInfo */ 0);
ret = FlashErase(&flashCfg,
/* dest */ DEMO_TARGET_ADDR,
/* size */ BANK2_BLOCK_SIZE,
/* key */ ERS_KEY);
FillDemoBuffer();
ret = FlashProgram(&flashCfg,
/* size */ sizeof(demoBuf),
/* pSource */ (uint32_t)demoBuf);
ret = FlashVerifyProgram(&flashCfg,
/* pSource */ (uint32_t)demoBuf,
/* margin */ VERIFY_ALL);
return ret;
%3CLINGO-SUB%20id%3D%22lingo-sub-2147517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Empc5646b%E3%81%AEssdConfig%E3%81%AE%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%3CP%3EMPC5646B%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A7%E4%B8%8A%E4%BD%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E4%BF%9D%E8%AD%B7%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82MPC5602B%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9F%E4%BE%8B%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E4%B8%8B%E9%83%A8%E3%81%AB%E3%81%97%E3%81%8B%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%202%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%90%E3%83%B3%E3%82%AF%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EMPC5646%20%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AF%E3%81%A9%E3%81%93%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AB%E3%81%82%E3%82%8B%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E7%A9%BA%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%83%AD%E3%83%83%E3%82%AF%E8%A7%A3%E9%99%A4%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E6%99%82%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC300%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F*%20LOW%20PRIMARY%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%20*%2F%3CBR%20%2F%3E%20ret%20%3D%20pSetLock(%26amp%3BssdDataConfig%2C%20LOCK_LOW_PRIMARY%2C%200x0U%2C%20FLASH_LMLR_PASSWORD)%3B%3CBR%20%2F%3E%20ret%20%7C%3D%20pGetLock(%26amp%3BssdDataConfig%2C%20LOCK_LOW_PRIMARY%2C%20%26amp%3BblkLockEnabled%2C%20%26amp%3BblkLockState)%3B%3CBR%20%2F%3E%20blkLockState%20%26amp%3B%3D%20(0xFFFFFFFF%20%26gt%3B%26gt%3B%20(32%20-%20ssdDataConfig.lowBlockNum))%3B%3CBR%20%2F%3E%20if%20((C90FL_OK%20!%3D%20ret)%20%7C%7C%20blkLockState)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%88%E3%83%A9%E3%83%83%E3%83%97(ret)%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%2F*%20LOW%20SECONDARY%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%20*%2F%3CBR%20%2F%3E%20ret%20%3D%20pSetLock(%26amp%3BssdDataConfig%2C%20LOCK_LOW_SECONDARY%2C%200x0U%2C%20FLASH_SLMLR_PASSWORD)%3B%3CBR%20%2F%3E%20ret%20%7C%3D%20pGetLock(%26amp%3BssdDataConfig%2C%20LOCK_LOW_SECONDARY%2C%20%26amp%3BblkLockEnabled%2C%20%26amp%3BblkLockState)%3B%3CBR%20%2F%3E%20blkLockState%20%26amp%3B%3D%20(0xFFFFFFFF%20%26gt%3B%26gt%3B%20(32%20-%20ssdDataConfig.lowBlockNum))%3B%3CBR%20%2F%3E%20if%20((C90FL_OK%20!%3D%20ret)%20%7C%7C%20blkLockState)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%88%E3%83%A9%E3%83%83%E3%83%97(ret)%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%2F*%20HIGH%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%EF%BC%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%89*%2F%3CBR%20%2F%3E%20ret%20%3D%20pSetLock(%26amp%3BssdDataConfig%2C%20LOCK_HIGH%2C%200x0U%2C%20FLASH_HBLR_PASSWORD)%3B%3CBR%20%2F%3E%20ret%20%7C%3D%20pGetLock(%26amp%3BssdDataConfig%2C%20LOCK_HIGH%2C%20%26amp%3BblkLockEnabled%2C%20%26amp%3BblkLockState)%3B%3CBR%20%2F%3E%20blkLockState%20%26amp%3B%3D%20(0xFFFFFFFF%20%26gt%3B%26gt%3B%20(32%20-%20ssdDataConfig.highBlockNum))%3B%3CBR%20%2F%3E%20if%20((C90FL_OK%20!%3D%20ret)%20%7C%7C%20blkLockState)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%88%E3%83%A9%E3%83%83%E3%83%97(ret)%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Example%20ssdConfig%20for%20mpc5646b%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%82%8B%E5%90%8C%E5%83%9A%E3%81%A8%E8%A9%B1%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%BD%BC%E3%81%AF%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Example%20ssdConfig%20for%20mpc5646b%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESSD_C90FL%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20MPC5646B%20%E3%81%AE%202%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%90%E3%83%B3%E3%82%AF%20(%E4%B8%8A%E4%BD%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%2F%20BANK2)%20%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%93%E3%81%AEThread%E3%81%AE%E5%85%83%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E8%A9%B3%E7%B4%B0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EBANK1%20%E3%81%AF%E3%80%81%E6%A8%99%E6%BA%96%E3%81%AE%20SSD_C90FL%20%E3%81%AE%E4%BE%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0CAN%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81BANK2%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%20ssd_config%20%E6%A7%8B%E6%88%90%E3%82%84%E6%AD%A3%E3%81%97%E3%81%84%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E3%81%BE%E3%81%A0%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E8%A9%A6%E3%81%97%E3%81%9FSO%3A%3C%2FP%3E%3CP%3EMPC5646B%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81BANK2%20%E3%81%AF%E3%83%8F%E3%82%A4%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFlashErase()%20%E3%81%A8%20FlashProgram()%20%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A8%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E5%AE%9F%E9%A8%93%E7%9A%84%E3%81%AB%E7%89%B9%E5%AE%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E6%88%90%E5%8A%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EFlashSetLock()%20%E3%81%AB%E3%82%88%E3%82%8B%E9%AB%98%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E8%A7%A3%E9%99%A4%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%9E%E3%82%B9%E3%82%AF%E5%80%A4%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBANK2%20%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%20SSD_CONFIG%20%E6%A7%8B%E9%80%A0%E8%A8%AD%E5%AE%9A%20(%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E6%95%B0)%E3%80%82%3C%2FP%3E%3CP%3EBANK2%20%E3%81%AB%E5%88%A5%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20BANK1%20%E3%81%A8%E5%90%8C%E3%81%98%E3%83%99%E3%83%BC%E3%82%B9%E3%82%92%E5%85%B1%E6%9C%89%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8A%E4%BD%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81lowBlockLock%E3%80%81midBlockLock%E3%80%81highBlockLock%20%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%AF%E5%80%A4%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFlashErase()%20%E3%81%8A%E3%82%88%E3%81%B3%20FlashProgram()%20%E3%81%AE%E5%8B%95%E4%BD%9C%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81MPC5646B%20%E4%B8%8A%E3%81%AE%20BANK2%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMPC5646B%20%E3%81%AE%20BANK2%20%E3%81%8C%E8%A9%B3%E7%B4%B0%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%AE%9F%E7%94%A8%E7%9A%84%E3%81%AA%E3%82%B3%E3%83%BC%E3%83%89%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%20(%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%2F%E4%BE%8B%E3%81%B8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF)%20%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81BANK2%20%E3%81%AE%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%89%E3%83%A9%E3%83%95%E3%83%88%E6%A7%8B%E6%88%90%E3%81%A8%E3%82%B3%E3%83%BC%E3%83%89%20%E3%82%B9%E3%82%B1%E3%83%AB%E3%83%88%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CEM%3E%23include%20%22ssd_types.h%22%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23include%20%22ssd_c90fl.h%22%20%2F%2F%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E5%90%8D%E3%81%AFSSD%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%20TODO%3A%20MPC5646B%20RM%20%E3%81%AE%E6%AD%A3%E7%A2%BA%E3%81%AA%E5%80%A4%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%20%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E5%9F%8B%E3%82%81%E3%82%8B%EF%BC%9A%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E-%20P-Flash%20%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20(%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%A2%E3%83%AC%E3%82%A4)%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E-%20BANK2%EF%BC%88%E4%B8%8A%E4%BD%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%EF%BC%89%E9%96%8B%E5%A7%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E6%95%B0%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E-%20%E3%82%B7%E3%83%A3%E3%83%89%E3%82%A6%2FUTEST%E3%83%99%E3%83%BC%E3%82%B9%EF%BC%88%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%EF%BC%89%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E-%20%E9%AB%98%E3%81%84%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%2F%E9%81%B8%E6%8A%9E%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E4%BF%AE%E6%AD%A3%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E*%2F%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%23define%20PFLASH_BASE%200x00XXXXXXu%20%2F%2F%20TODO%3A%20%E3%83%99%E3%83%BC%E3%82%B9P%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23define%20BANK2_FIRST_BLOCK_ADDR%200x00YYYYYYu%20%2F%2F%20TODO%3A%20%E6%9C%80%E5%88%9D%E3%81%AE%E4%B8%8A%E4%BD%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E9%96%8B%E5%A7%8B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23define%20BANK2_BLOCK_SIZE%200x00040000u%20%2F%2F%20TODO%3A%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA%EF%BC%88%E4%BE%8B%EF%BC%9A256KB%EF%BC%89%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%23define%20BANK2_BLOCK_COUNT%200x00000004u%20%2F%2F%20TODO%3A%20%E4%B8%8A%E4%BD%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E6%95%B0%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%23DEMO_TARGET_ADDR%20(BANK2_FIRST_BLOCK_ADDR)%20%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%23define%20HIGH_BLOCK_SEL_MASK%200x00000001u%20%2F%2F%20TODO%3A%20%E4%B8%8A%E4%BD%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E9%81%B8%E6%8A%9E%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E4%BF%AE%E6%AD%A3%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23define%20HIGH_BLOCK_LOCK_MASK%200x00000001u%20%2F%2F%20TODO%3A%20%E9%AB%98%E3%81%84%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3ESSD_CONFIG%20ssdConfig%20%3D%20%7B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20pFlashBase%20*%2F%20PFLASH_BASE%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20uTestBase%20*%2F%200xXXXXXXu%2C%20%2F%2F%20TODO%3A%20UTEST%2F%E3%82%B7%E3%83%A3%E3%83%89%E3%82%A6%E3%83%99%E3%83%BC%E3%82%B9%EF%BC%88%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%EF%BC%89%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E4%BD%8E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%20*%2F%200%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E4%B8%AD%E9%96%93%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%20*%2F%200%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E6%9C%80%E5%A4%A7%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E6%95%B0%20*%2F%20BANK2_BLOCK_COUNT%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E6%83%85%E5%A0%B1%20*%2F%20NULL%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%20*%2F%200u%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%20*%2F%20NULL%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7D%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Euint32_t%20%E3%83%87%E3%83%A2%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5B64%5D%20%3D%20%7B0%7D%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E9%9D%99%E7%9A%84void%20FillDemoBuffer(void)%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E(uint32_t%20i%20%3D%200%3B%20i%20%26lt%3B%20(sizeof(demoBuf)%2Fsizeof(demoBuf%5B0%5D))%3B%20%2B%2Bi)%20%7B%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E3%83%87%E3%83%A2%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5Bi%5D%20%3D%200xA5A50000u%20%2B%20i%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7D%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7D%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eint%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%90%E3%83%B3%E3%82%AF2%E3%83%87%E3%83%A2(void)%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Euint32_t%20%E6%88%BB%E3%82%8A%E5%80%A4%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3EFLASH_SSD_CONFIG%20flashCfg%20%3D%20ssdConfig%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eret%20%3D%20FlashInit(%26amp%3BflashCfg)%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Eif%20(ret%20!%3D%20FTFx_OK)%20ret%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eret%20%3D%20FlashSetLock(%26amp%3BflashCfg%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%83%AD%E3%83%BC%E3%83%AD%E3%83%83%E3%82%AF%20*%2F%200x00000000u%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%83%9F%E3%83%83%E3%83%89%E3%83%AD%E3%83%83%E3%82%AF%20*%2F%200x00000000u%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%83%8F%E3%82%A4%E3%83%AD%E3%83%83%E3%82%AF%20*%2F%20~HIGH_BLOCK_LOCK_MASK)%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Eif%20(ret%20!%3D%20FTFx_OK)%20ret%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eret%20%3D%20FlashBlockSelect(%26amp%3BflashCfg%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E4%BD%8E%E9%81%B8%E6%8A%9E%20*%2F%200x00000000u%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%83%9F%E3%83%83%E3%83%89%E3%82%BB%E3%83%AB%20*%2F%200x00000000u%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%83%8F%E3%82%A4%E3%82%BB%E3%83%AB%20*%2F%20HIGH_BLOCK_SEL_MASK%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E9%81%B8%E6%8A%9E%E6%83%85%E5%A0%B1%20*%2F%200)%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Eif%20(ret%20!%3D%20FTFx_OK)%20ret%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eret%20%3D%20FlashErase(%26amp%3BflashCfg%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E5%AE%9B%E5%85%88%20*%2F%20DEMO_TARGET_ADDR%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%82%B5%E3%82%A4%E3%82%BA%20*%2F%20BANK2_BLOCK_SIZE%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%82%AD%E3%83%BC%20*%2F%20ERS_KEY)%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Eif%20(ret%20!%3D%20FTFx_OK)%20ret%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EFillDemoBuffer()%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Eret%20%3D%20FlashProgram(%26amp%3BflashCfg%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E5%AE%9B%E5%85%88%20*%2F%20DEMO_TARGET_ADDR%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%82%B5%E3%82%A4%E3%82%BA%20*%2F%20sizeof(demoBuf)%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20pSource%20*%2F%20(uint32_t)%E3%83%87%E3%83%A2%E3%83%90%E3%83%83%E3%83%95%E3%82%A1)%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Eif%20(ret%20!%3D%20FTFx_OK)%20ret%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3Eret%20%3D%20FlashVerifyProgram(%26amp%3BflashCfg%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E5%AE%9B%E5%85%88%20*%2F%20DEMO_TARGET_ADDR%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%82%B5%E3%82%A4%E3%82%BA%20*%2F%20sizeof(demoBuf)%2C%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20pSource%20*%2F%20(uint32_t)%E3%83%87%E3%83%A2%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%80%81%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%2F*%20%E3%83%9E%E3%83%BC%E3%82%B8%E3%83%B3%20*%2F%20VERIFY_ALL)%3B%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3Eret%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%7D%3C%2FEM%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Example%20ssdConfig%20for%20mpc5646b%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149290%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8B%E3%82%89%E3%81%AF%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x180000%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B%20BANK2%20%E3%81%AE%20SSD_C90FL%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AB%E3%82%88%E3%82%8B%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E4%BE%8B%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESSD_C90FL%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x180000%20%E3%82%88%E3%82%8A%E4%B8%8A%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%82%B3%E3%83%BC%E3%83%89%20A00%20%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%81%AF%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%20(%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%97)%20%E3%81%8C%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%82%B3%E3%83%BC%E3%83%89%20200%20%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESSD_C90FL%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20MPC5646B%20%E3%81%AE%E5%8B%95%E4%BD%9C%E4%BE%8B%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%20%E3%81%BE%E3%81%9F%E3%81%AF%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%20SSD_CONFIG%20%E3%81%AE%20BANK2%20%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E6%A7%8B%E6%88%90%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%A7%81%E3%81%8C%E8%A9%A6%E3%81%97%E3%81%9F%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%99%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ElowBlockNum%20%3D%2012%E3%80%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eid%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%20%3D%204%2C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%8F%E3%82%A4%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%20%3D%2016%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Example%20ssdConfig%20for%20mpc5646b%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3EMPC5646%20%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AF%E3%81%A9%E3%81%93%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AB%E3%81%82%E3%82%8B%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E7%A9%BA%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%83%AD%E3%83%83%E3%82%AF%E8%A7%A3%E9%99%A4%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E6%99%82%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC300%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E4%BE%8B%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx-Knowledge-Base%2FMPC5-software-example-list%2Fta-p%2F1102445%23MPC5646C%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx-Knowledge-Base%2FMPC5-software-example-list%2Fta-p%2F1102445%23MPC5646C%3C%2FA%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3EMPC5646B%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A7%E4%B8%8A%E4%BD%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E4%BF%9D%E8%AD%B7%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82MPC5602B%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9F%E4%BE%8B%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E4%B8%8B%E9%83%A8%E3%81%AB%E3%81%97%E3%81%8B%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%202%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%90%E3%83%B3%E3%82%AF%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%81%A8%E6%A8%A9%E9%99%90%E3%81%AE%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A8%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%94%E3%81%A8%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E4%BF%9D%E8%AD%B7%E3%82%92%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1754551315487.png%22%20style%3D%22width%3A%20736px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1754551315487.png%22%20style%3D%22width%3A%20736px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351309i7422F2BFAB2A2AB9%2Fimage-dimensions%2F736x152%3Fv%3Dv2%22%20width%3D%22736%22%20height%3D%22152%22%20role%3D%22button%22%20title%3D%22petervlna_0-1754551315487.png%22%20alt%3D%22petervlna_0-1754551315487.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_1-1754552476960.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_1-1754552476960.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351321iA5415C5022433DA6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22petervlna_1-1754552476960.png%22%20alt%3D%22petervlna_1-1754552476960.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%20HBL%20%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_2-1754552564147.png%22%20style%3D%22width%3A%20552px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_2-1754552564147.png%22%20style%3D%22width%3A%20552px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351325i71DCACDB3E88326B%2Fimage-dimensions%2F552x149%3Fv%3Dv2%22%20width%3D%22552%22%20height%3D%22149%22%20role%3D%22button%22%20title%3D%22petervlna_2-1754552564147.png%22%20alt%3D%22petervlna_2-1754552564147.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_3-1754553179513.png%22%20style%3D%22width%3A%20558px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_3-1754553179513.png%22%20style%3D%22width%3A%20558px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351343iF7A2994E1F9515E2%2Fimage-dimensions%2F558x258%3Fv%3Dv2%22%20width%3D%22558%22%20height%3D%22258%22%20role%3D%22button%22%20title%3D%22petervlna_3-1754553179513.png%22%20alt%3D%22petervlna_3-1754553179513.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%2F*%20HLB%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%20*%2F%3CBR%20%2F%3E%20CFLASH.HLB.R%20%3D%200xB2B22222%3B%20%2F*%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%20*%2F%3CBR%20%2F%3E%20CFLASH.HLB.R%20%3D%200x00000FFF%3B%20%2F*%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEHLB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
