ECC RAM Error Injection on MPC5644A
1,602件の閲覧回数
tunayan
Dear Community Users,
I am using mpc5644A EVB kit with CW 10.6
I have a problem with ECC Ram check. I tried to follow AN5200 application note but it was not work for me.
So basically i am doing below operation;
#define ECSM_ECR_ERNCR_MASK    0x02 // RAM Noncorrectable
//INIT
ECSM.ECR.R = (uint8_t)ECSM_ECR_ERNCR_MASK ; // non-correctable RAM ECC error
//FORCE TO GENERATE ERROR
ECSM.EEGR.R = (uint16_t)(ECSM_EEGR_FR1NCI_MASK | 1);
//GENERATE WRONG READ OP
test[0] = 0xCAFEBEEF;
//FOUND ECC ERROR
test_read = test[0];
In that line, i assume that ECSM.ESR.B.RNCE must be "1". But this register seems "0".
I am doing that operation with debug mode. Is it important? How can i inject a RAM error to system?
Thanks all.
1,207件の閲覧回数
davidtosenovjan
I must admit I have an error in my AN5200 Example 1 source code. I cannot imagine how it happened. Hoping it'll be corrected early in our public web.
Corrected example you may download here:
Example MPC5634M_2b_RAM_ECC_error_injection CW210
Following code line is incorrect
/* Force internal SRAM one non-correctable data error */
and it should be as follows
ECSM.EEGR.R = (uint16_t)(ECSM_EEGR_FR1NCI_MASK | 32);
The root cause of this issue is that basically that Table 3 of AN5200 is valid for MPC5634M as well.
I am very sorry for my embarrassing fault.
3 返答(返信)
1,207件の閲覧回数
davidtosenovjan
Just to inform you - Revision 1 of the document is now officially published and mentioned error is corrected in the Example 1.
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN5200.pdf
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN5200SW.zip
1,207件の閲覧回数
tunayan
Problem is solved. You are right
Thank you.
1,208件の閲覧回数
davidtosenovjan
