Does MPC5777 support I2C ?
2,087件の閲覧回数
hwdesign123
Dear All,
   I wanna use I2C Bus on MPC5777C. Does this chip support I2C ?
   If MPC5777C don't support I2C, can I simulate it with etpu or emios? Is there any example? Thank you!
2 返答(返信)
1,998件の閲覧回数
davidtosenovjan
Hi, I2C module is not present with MPC5777C.
For connection of external device you may use DSPI module (recommended).
If I2C is necessary then you could possibly also use I2C function running on eTPU module (I would not recommend because number of required pins is doubled). Such function is provided by third-party provider:
https://www.ashware.com/i2c-driver
1,998件の閲覧回数
hwdesign123
Thank you very much !
