Differences between MPC5554 and MPC564xA
1,232 次查看
tiganhee
hello,
Our company once used MPC5554. Now we want to use MPC564xA for product development. Two questions are asked:
1. What's the main difference between MPC5554 and MPC564xA?
2. Can the driver code of MPC5554 be transplanted directly to MPC564xA?
1 回复
1,179 次查看
davidtosenovjan
Hi, there are two documents, one showing transition from MPC5566 to MPC5644A, with second you can compared MPC5554 and MPC5566 (very similar devices).
A Guide to Transitioning from the MPC5566 to the MPC5644A:
https://www.nxp.com/docs/en/application-note/AN4113.pdf
MPC55xx Family Overview:
https://www.nxp.com/docs/en/engineering-bulletin/EB659.pdf
MPC5554 and MPC5644A are offered with different packages, but they are very similar are peripherals are mostly backward compatible.
