Codewarrior (Eclipse IDE) - MAP Tools 56xx
1,892 次查看
robertwynn
I am using Codewarrior (Eclipse IDE) v11.1 for 56xx.
I would like to see  flash/ram usage in my project. I understand this information is in the MAP file, but it is time consuming to extract.
Does anybody have a tool or instructions that will do this?
https://mcuoneclipse.com/2014/05/04/printing-code-size-information-in-eclipse/  talks about the same thing, but for an arm processor.
3 回复数
1,821 次查看
lukaszadrapa
Hi Robert,
you can find that directly in the map file. In fact, it's the same format of data as returned from AMAP tool for ARM, for example. There are sizes of individual sections. Scroll down in the map file and you will find Memory map section. Something like:
Lukas
1,821 次查看
robertwynn
Thanks Lukas.
I think this will answer my questions.
Is there a document that describes what goes in each section?
Robert
1,821 次查看
lukaszadrapa
Take a look at this document:
c:\Freescale\CW MCU v11.1\MCU\Help\PDF\MCU_Power-Architecture_Compiler.pdf
There's some brief explanation in 12.2.4 Section Control Directives. Or just search for names of the sections in the document to find more details.
Lukas
