CodeWarrior 2.1 and CodeWarrior 10.6 PE Driver
5,502 次查看
Yorn
PE Driver(multilink_universal_install_12.2 ) can use on CodeWarrior 2.1 IDE ,but  it can not use on the CodeWarrior 10.7, it must instatll 12.7. Is PE Driver can used on the both CodeWarrior 2.1 IDE and CodeWarrior 10.7 IDE?
5,377 次查看
stanish
Can you try to install P&E patch available here:
https://www.pemicro.com/downloads/download_file.cfm?download_id=463
This should update the support for all compatible PEmicro interfaces into CW MPC55xx/56xx v2.10
Stan
9 回复数
5,480 次查看
petervlna
@stanish could you comment here?
Peter
5,426 次查看
stanish
I've just installed Drivers 12_7 on my Windows 10 64bit machine and use it with CodeWarrior for MPC55xx/56xx v2.10 and
  • PEmicro Multilink FX (black probe) rev.C
  • PEmicro Multilink PowerPC Nexus (blue probe) rev.
All configurations work as expected.
Do you observe any issue on your side?
If yes, can you attach the error screenshot?
Hope it helps.
Stan
4,624 次查看
ArunMukundan
Could you please help me to resolve this error.
PFB is me driver details
The USB indication led is turned on and it is blue color.
Still the software is not detecting the hardware.
5,410 次查看
Yorn
Hi,Thank you for your replying. My window is Windows 11 64bit , My drive and PE type is as following figure
When debuging on  CodeWarrior 2.10 using multilink_universal_install _12.7. It is not ok,
When debuging on  CodeWarrior 2.10 using multilink_universal_install _12.0. It is  ok,
5,378 次查看
stanish
Stan
5,128 次查看
ZhaoDinan
Thank you, I solved the PEmicro recognition problem using the method above, but now I'm encountering the "load fail" issue.
when I clicked the "connect(Reset)"button ,the new problem was appeared as below. And how can I solve this problem ?(load aborted)
5,120 次查看
Yorn
IT is not found elf.file ,reload the elf file to the path
5,086 次查看
ZhaoDinan
Thank you!
5,361 次查看
Yorn
%3CLINGO-SUB%20id%3D%22lingo-sub-1947726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECodeWarrior%202.1%20%E5%92%8C%20CodeWarrior%2010.6%20PE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1947726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88multilink_universal_install_12.2%EF%BC%89%E5%8F%AF%E4%BB%A5%E5%9C%A8%20CodeWarrior%202.1%20IDE%20%E4%B8%8A%E4%BD%BF%E7%94%A8%EF%BC%8C%E4%BD%86%E4%B8%8D%E8%83%BD%E5%9C%A8%20CodeWarrior%2010.7%20%E4%B8%8A%E4%BD%BF%E7%94%A8%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%AE%89%E8%A3%85%2012.7%E3%80%82PE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%9C%A8%20CodeWarrior%202.1%20IDE%20%E5%92%8C%20CodeWarrior%2010.7%20IDE%20%E4%B8%8A%E4%BD%BF%E7%94%A8%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1972602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ACodeWarrior%202.1%20%E5%92%8C%20CodeWarrior%2010.6%20PE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1972602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1972054%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ACodeWarrior%202.1%20%E5%92%8C%20CodeWarrior%2010.6%20PE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1972054%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%89%BE%E4%B8%8D%E5%88%B0%20elf.file%EF%BC%8C%E8%AF%B7%E9%87%8D%E6%96%B0%E5%8A%A0%E8%BD%BD%20elf%20%E6%96%87%E4%BB%B6%E5%88%B0%E8%B7%AF%E5%BE%84%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1952790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ACodeWarrior%202.1%20%E5%92%8C%20CodeWarrior%2010.6%20PE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1952790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1952008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ACodeWarrior%202.1%20%E5%92%8C%20CodeWarrior%2010.6%20PE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1952008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%AE%89%E8%A3%85%E6%AD%A4%E5%A4%84%E6%8F%90%E4%BE%9B%E7%9A%84%20P%26amp%3BE%20%E8%A1%A5%E4%B8%81%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Fdownloads%2Fdownload_file.cfm%3Fdownload_id%3D463%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.pemicro.com%2Fdownloads%2Fdownload_file.cfm%3Fdownload_id%3D463%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E5%BA%94%E8%AF%A5%E6%9B%B4%E6%96%B0%E6%89%80%E6%9C%89%E5%85%BC%E5%AE%B9%20PEmicro%20%E6%8E%A5%E5%8F%A3%E7%9A%84%E6%94%AF%E6%8C%81%E5%88%B0%20CW%20MPC55xx%2F56xx%20v2.10%3C%2FP%3E%0A%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E
