CMU
CMU
4,065 次查看
Amr_Awny
On writing 0 to the SELCTL (7th bit) to MC_CGM_AC3_SC & MC_CGM_AC4_SC registers, Freemaster doesn't see the board COM port
On writing 1 to On writing 0 to the SELCTL (7th bit) to MC_CGM_AC3_SC and MC_CGM_AC4_SC register to choose the  8-40 MHz XOSC as a clock source, I don't get the desired output in the MC_ME_GS register in the S_SYSCLK (28–31) bits, that I expect to be 0001 (4-40 MHz XOSC)
4,025 次查看
Amr_Awny
Thanks for the response
the device used is MPC5744p
Kindly find the attached files
3,995 次查看
lukaszadrapa
if it is related to MBDT, I would suggest rather this community space:
https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/bd-p/mbdt
Lukas
4,049 次查看
lukaszadrapa
which device is that? Could you share your initialization code?
Lukas
