CAN Peripheral
CAN Peripheral
vignesh_v
Does MPC5777c Flex CAN support only extended frame or also supports standard frame? Is there any means to get an example to perform CAN loopback tests on ports A nd B
PetrS
if you meant standard/extended IDs, then yes, FlexCAN supports both.
If you are interested in extended data in CAN FD frame, then no,  MPC5777C's FlexCAN does not support CAN FD, just a MCAN module support this.
Links to MPC5777C FlexCAN and MCAN examples are available on https://community.nxp.com/docs/DOC-329623
BR, Petr
